I have configured my magic mouse 2 with BTT for dragging with a double tap.
It works when dragging things in folders, moving folders on the desktop etc, however it doesn't work in these two cases:
- In mission control, I cannot drag windows (e.g. on a different desktop)
- If a folder in opened in "grid" view, I cannot drag elements inside this folder (e.g. on the desktop)
In both cases, as the first tap is received, the window and the folder element are respectively selected or opened as just one tap is received.
Pls note that the expected behaviour works with the trackpad properly configured (i.e. SysPreferences -> Accessibility -> Mouse & Trackpad -> Trackpad options -> Enable dragging without drag lock)
Macbook pro 2019
OS 10.14.6
BetterTouchTool 3.579 (1722)
