- Type of Mac: 14” M1 Pro MacBook Pro
- macOS version: Sequoia 15.7.2
- BetterTouchTool version: 2.428 (788)
Hello! I tried looking for similar issues but I suspect its because my copy of BTT is too old. It used to work fine on the base model M1 Macbook Air, but i have upgraded to a M1 Pro Macbook Pro since then and updated MacOS and since then:
I do have the option enabled to run BTT when login / start up. However the behaviour isn’t consistent and i have to manually start BTT often.
BTT doesn’t run automatically when I wake my mac from sleep. I don’t have any ticker box for Restart after sleep, and again, I have to manually wake Mac from sleep
I know my copy of BTT is really old, maybe my time is up but just wanted to know for sure if that’s the case.
