BTT closes unexpectedly when using ‘Start Recording'
Whenever I activate ‘Start Recording Drawing/Mouse Gesture,’ an error occurs, and the application closes. My operating system is macOS 15.1 (24B83) and BTT 4.839. Any solutions? Thank you
could you send the crashlog to me? (you can find it in the macOS console.app)
It works fine here, but maybe some specific setting is causing this.
Thank you for your quick response. “I’m sorry for my inexperience, but I can’t figure out how to send the file. I have it located in the ‘diagnosticReports’ folder, but I can’t select it for sending. Best regards.
BetterTouchTool-2024-11-09-104924.ips.zip (8.5 KB)
I’ve compressed it to see if that works.
I reinstalled the program, and everything was resolved. Thank you
