BTT Capturing my screen without permission
Screenshot 2023-10-20 at 7.34.17 PM
Im not sure what to do... Ive tried revoking screen recording access but it's still capturing my screen without my permission
apps on macOS can not capture your screen without permission (unless there is a bug in macOS)
However even if you have given the permission, BTT will only record (parts) of the screen for specific features. For example:
  • the screenshot actions (obvious)
  • the window switcher (for the window previews)
  • the float window on top action
  • the NotchBar feature (to capture the menubar status icons). If you don’t use the NotchBar, you can didable it in the settings.
