BTT and VoiceOver accessibility
Hello everyone,
I have recently discovered Better Touch Tool on MacOS and I have started to use it. however since I am fully blind I rely on the VoiceOver feature built into my Mac that allows me to read the screen efficiently. While the majority of the application is accessible with VoiceOver, there are some improvements which could be made in order to improve the user experience, namely, there are many unlabelled controls in the main screen of the app, which you need to press one by one to figure what they mean. Then, when there is an any hotkey field in the application, its usage is hard with VoiceOver, as I need to rely on then mouse simulation features to click in it and set the required data.
For a power user like me, bTT is something totally wonderful, however with current difficulties it is a little bit hard to use.
If you need any more insight on the VO accessibility, feel free to ask.
Hi. Sorry to bump this up but the state of things remains mainly unchanged. Can somehing be done about it?
I‘ll have a look to at least add accessibility labels to the main window controls, but I don’t think I can do it for all the many configuration options :-/
Hi!
Do sighted people have only icons for those options, no text? If there's text you can use that as an AccessibilityLabel.
most have some text (but in that case no change is necessary, right?)
The problem is, the whole configuration UI has grown over 15 years and I‘m sure there are many places that are not good accessibility wise.
I am so happy to see you wish to improve on it. I will let you know when I manage to test. Thank you! Let me know if you have a test version.
