I have few custom snap areas. I checked "Make snap area invisible" for each other. However, once I modify settings for one of snap area, the option is reset for all of them.
Workaround: create and configure all snap areas first, then go through all snaps settings and check "Make snap area invisible". Once you add new snap or reconfigure them, all snaps are visible again.
