I never print anything, but I do pin tabs a lot. I would love to be able to use ⌘P to right click the current tab and pin it. I've tried to figure out a way to do this, but am suspecting that it involves some scripting. Can anyone confirm or deny this is possible? Thanks!
You can just use the "Trigger Menubar Menu Item" action to trigger the Pin Tab item.
In Safari & Chrome it would be configured with "Window;Pin Tab"
Awesome! Thank you Andreas. It's a shame Firefox doesn't have this menubar item available. There is this add-on for now, I suppose.
Follow-up question. Is it possible to group these applications so I only need to define the trigger once? Thanks again!
Niiiiiice! Thank you!
