Brightness percentage and Volume percentage script issues
Hi all. I’ve been using BTT for many years with the same setup and haven’t really changed it. However, at some stage a couple of years ago, my Brightness and Volume percentage scripts started acting up and whenever I restart my Mac, the Brightness and Volume percentage values are identical (which is incorrect)…and the only way to get them to display the correct values is to momentarily disable the Brightness script in the BTT Touch Bar Trigger Configuration, and then re-enable it. Both presets are below….can anyone see why this issue happens every time I restart my Mac?
Cheers
Gary
Volume Percentage script.bttpreset (27.8 KB)
Brightness Percentage script.bttpreset (16.8 KB)
