Hi all,
Newbie on the forum.
The Big Sur minor update a few days ago completely knee capped BTT.
All my shortcuts disappeared and I wasn't able to add any. I then noticed significant CPU usage and had to continually force quit BTT to the point where reboots with 'don't launch at login' didn't help so I had to uninstall BTT.
Is there something I should know? I miss my BTT!
Thanks,
Alex
- Type of Mac:
- macOS version:
