I've download the latest BetterTouchTool and am on the latest Mac OS Mojave at 10.14.4. It installs fine, and I move it to my Applications folder. As soon as open it, it pops up a welcome screen and immediately quits.
Then, it seems to try and restart itself, and flashes on and off in my menu bar (so it opens, closes, opens, closes, etc. see the GIF below). If I click it while it's open on the menu bar, it stops flashing while I have the menu open, however if I try to open preferences or anything it opens for a second and then immediately quits again. I'm not sure what to do about this.
It seems to work on other Macbooks with no problem, and I don't know why it just doesn't like this one Macbook (which it has been installed on and working previously).
I have restarted my computer and I've tried to uninstall BetterTouchTool fully via CleanMyMac 3 and reinstall it (so maybe that should delete some extra settings), but maybe there is something else I can do to completely wipe it.
N/A
- Type of Mac: Macbook Pro 15inch (2015-ish version)
- macOS version: Mac OS Mojave 10.14.4
- BetterTouchTool version: Latest downloaded from website (can't get it to open and fully check)
