BetterSnapTool on new monitor (same resolution)
I replaced my monitor (Viewsonic) because it started to have a backlight issue with an LG. They're the same screen size, resolution, and refresh rate.
However, with this new monitor, none of my snap areas are available.
Does anyone have any recommendations?
Thanks in advance!!
  • Type of Mac: Macbook Pro 14" M2 Max
  • macOS version: Sonoma 14.2.1
  • BetterSnapTool version: 1.9.9
unfortunately there is currently no good way to transfer the snap areas to a new monitor.
You'd need to edit the ~/Library/Application Support/BetterSnapTool/storedata file (while BST is quit) to edit the display.
If you want you can send it to me (andreas@folivora.ai), then I can try to modify it.
Hi Andreas! Thank you! I will email the file in a moment...
