Mouse, logitech mx anywhere 2s
- Type of Mac: macbook pro 16
- macOS version: 10.15.4
- BetterSnapTool version: 1.9.3
When you try to move the inventory items in dota 2 at the bottom panel from one cell to other - bettersnaptool forces to mouse to go automatically to top of the screen which makes the game unplayable, the same happens if you LMB click and hold anywhere at the bottom 5cm area. I turned off bettersnaptool and it works perfect, no issues. Magnet app meanwhile does not cause such an issue. something is going on with snap areas, i am using default setup of bettersnaptool, no additional customizations.
