better touch tool secure input activated by:
better touch tool secure input activated by: Finder (PID: 646). limited shortcut functionality
I've also gotter this message from Brave Browser
Anyone else getting this (very frequent now)?
Mac Studio
OSX 15.1.1
BTT V 4.902
Note:
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
It's usually some faulty app that shows a password input but forgets to deactivate secure input again. Unfortunately there is nothing BTT can do about it. The app it shows is also only a "best guess", there are some apps that can not be detected and for these the system falls back to "login window", "finder" or similar.
How do I correct it so it can be used again?
figure out which app really causes it, then quit it. If it is really a system app that caused it, you might need to logout and back in again.
Just logged out/in again, but still having message regarding finder.
try to relaunch Finder (ctrl+opt+right-click the finder icon, then choose relaunch). If that doesn't help it is not caused by Finder.
What worked: Force quitting finder, restarting BTT.
Sorry to bother you, but this is happening again, and my previous solution isn't working this time. the error is saying "Secure input activated by: Finder (PID:1199). limited shortcut functionality."
NordPass was the culprit... All good now.
