I was checking out Golden Chaos and I did not like it a lot. I was messing around with some settings and I actually made a good preset. It has YouTube functions too!
And if you click and hold the weather widget you will also get a full weather forecast:
To get this preset first download this: GoldenChaos-BTT 3.392.bttpreset (11.7 MB)
Then change that preset to the master preset
Then download this preset: Yay.bttpreset (257.2 KB)
Now your Touch Bar should have all the functions I have!
