Best approach for Huion K20 keypad
Im hoping to use the Huion k20 keypad with BTT and wondering the best approach.
From what I can tell I can’t get the device to input unique inputs and I couldnt get the Device analyser in Generic Devices in BTT to pickup any of the inputs when pressed. I have installed the Huion software, so maybe this is taking over the input instead of allowing BTT to detect the inputs?
These are the options the software gives for the keys:
Either way, I think I can live with this and just setup keyboard shortcuts instead and control those with BTT but just wanted to ask if there was a better approach.
Thanks
So ive just tried setting keyboard key (keyboard shortcut) in the Huion settings as shown above but that doesn’t get recognised by BTT :frowning:
Solving my own problem here. Ive set CMD + CTRL + [letters] with the huion software and detected those as key sequences. I think this works ok :slight_smile:
So did you figure out how to have BTT recognize your Huion buttons with or without the Huion driver software? Asking because I have the Xppen ACK05 that has a similar challenge.
Sorry slow reply - i didnt get BTT to directly recognise them as unique keys, so i had to use the Huion software to send unique keyboard shortcuts, which i could then use in BTT to do what i want. Hope that helps
No worries at all. This was a year-old post to begin with. Your answer does help. I was just hoping to avoid needing both BTT and the device's software installed, but I've since learned the way they designed these, the keys aren't detected without their software.
