Bear note link to BTT shortcut.
I want to access a specific note page created in Bear using a BTT shortcut. Of course, I have the link from Bear, and it looks like this:
bear://x-callback-url/open-note?id=4AB9F41C-F65D-4F31-9CB5-5F2C377DA444
How can I set up a BTT shortcut to access this note every time?
you can use the "Open URL / Open URL With Selection" action:
Thanks Andreas, I was able to achieve what I wanted. Now that I’ve done this, I want the cursor and its focus to automatically move to the Bear note so I can start writing right away—eliminating the steps of opening the note and clicking to focus on it. Is there any way to do this?
Regards, Aaron
Is there a way to right-click in a specific app to bring up a menu and then select a specific item from that menu (in my case, “toggle folding”) by clicking it?
you can try the „trigger context menu item“ action, it doesn’t work with all apps unfortunately
maybe sending the tab key would be enough?
Or use the move
mouse action followed by a left click action
