Alright, the first version of the battery widget is out now with 2.850
Still a bunch more work to do on the system stats modal.
Hey @GoldenChaos, I really like your battery widget, but I wanted to also show the remaining time in there, ideally in two lines like this:
29%
3:33
Getting it to show the remaining time was easy:
But I can't get it to show the information in two lines.
if I insert an enter
press oder \n
in the return value between the percent value and the time remaining value, the output, if you click on Run Script
, looks good, but on the Touch Bar it only shows a series of letters, which are the code for the current battery image, but I really don't know why...
return "{\"text\":\"" & percentage & "%
" & timeremaining & "\", \"icon_data\":\"" & batteryIcon & "\"}"
Maybe you or someone else knows the reason for this?
set batteryStatus to do shell script "pmset -g batt"
set powerSource to word 4 of batteryStatus
set percentage to word 11 of batteryStatus as integer
set charging to word 12 of batteryStatus
set timehour to word 13 of batteryStatus
set timeminutes to word 14 of batteryStatus
set timeremaining to timehour & ":" & timeminutes
if charging is "discharging" then
if percentage is greater than or equal to 96 and percentage is less than or equal to 100 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAs0lEQVR42u2WQQrDIBBFh3iP0hRK7MHjLoucIT1LXCZt1uZ1FaglOx2o4NsIs3jgCP8rUqlU/hosPZ5ACoGZHvurblnJxcotljtgpMUk3d7QMgIuHnvgmmW9F2CORwEwIkxJC5lEMECI5cBxpvDtKlfOi4G7lhxgodOTw6Ap3zTlFCvfCn3QBasjfzPQlZ0teSL3eR65qmVx1FyTJG7Oa06zoEWwODx7knbH43jUj1qlUg4fxZ8lasabhQ4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 86 and percentage is less than or equal to 95 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2WQQqDMBBFg96jNIVienCzy8Iz2LOYpbau4+tKaGzpwjjQQN4mMItHMgPzo1ShUPhrMLR4AikEBlrMVq2ZOIqJSyy3QIemTnp9jaYDbFz2wPmQ9p6AIS4FoFaKfmcr+rfbQ4jlwHru49OVr5wHjquUHGCkkZODk5TPknKylc+ZDnTEyMifOJq8d0vqyr3/WrmiYbHGXJUkrr7HnGRAK4XB4lmStAsey6181AqFfHgB7SnFu8OCs/4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 76 and percentage is less than or equal to 85 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQqDMBBFg96jNIVienCzc+EZ7FnMUlvX8XXlIioUGwcayNsEZvGYTGB+lMpkMn8NhhqHJwZPT41ZqzUjZzFyC+UWaNGUUbcv0bSADcsOuJ4y3gvQhyUPlErRHR5Ct+kefFgClvMom97XteTkvGi4S8kBBio5OTSS8klSTrLyKdEHHTAy8jcNVdq75feV+/y+ckXDYom5Ikpc7MecZEArhcHimKO0Mw7LI3/UMpl0+ADW1WYbk5lWXgAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 66 and percentage is less than or equal to 75 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJblHqYUSe/C4yyJnSM8Sl0mbtXldZWFowGIGKvg2wgiPUWG+ShUKhb8GQ4vDk4JnpMXs1ZqZs5i5hXIL9GjqpNPXaHrAhmUHXE+53gswhiUP1EoxRB9+OOwefFgCtjWWw973e9nJedFxl5IDTDRycugk5YuknGzlS6YPOmFk5G86mrxny+8j9xk/ckXDYou5KklcfY85yYBWCoPFsSZpVxyWR/moFQr58AGRs+aMzl3kdAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 56 and percentage is less than or equal to 65 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJd6j1EKJPXjcZZEzpGeJy6TN2ryusjAU0mAGKvg2wiCPUWG+ShUKhb8GS4MnkEJgoMFu1YaJs5i4xXIHdBh00uk1hg5wcdkD11Ou9wIMcSkAWin6H47d73QPIS4B67rPTu/bHdnJedFyl5IDjNRycmgl5bOknGzlc6YPOmJl5G9a6rxny5GR+zw6ckXDYo25KklcfY85yYBWCovDsyRpFzyOR/moFQr58AFAVIbsiXp9RAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 46 and percentage is less than or equal to 55 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlIlJEGgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj97sD9oe7BhyVgPfc41Pv2XnJyXrTcteQAI7WeHFpN+awpJ1n5nOiHjhgd+ZuWOu3dcmzlPn9buaphscZcESUuvsecZkCLYLA4lijtgsPykEwmkwwfsQgnTIxdnPMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 36 and percentage is less than or equal to 45 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlImIpEgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj9l1H7A92DD0vAeu5zoPft7eTkvGi5a8kBRmo9ObSa8llTTrLyOdEPHTE68jctddq75dfKfcasXNWwWGOuiBIX+zGnGdAiGCyOJUq74LA8JJPJJMMH497HnQsmWpMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 26 and percentage is less than or equal to 35 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlItouJA40kLcJDOQxk8B8kUwm89dgaHB4YvAMNJitumLiLCZuodwCHRVl1PQlFR1gw7IDrqc87wUYwpIHShH63ZD94e7BhyVgPbcc7n17Jzk5L1ruWnKAkVpPDq2mfNaUk6x8TvRDR4yO/E1LnfZu+b1yn/ErVzUs1pgrosTF95jTDGgRDBbHEqVdcFgekslkkuED2NZn/WdIKR8AAAAASUVORK5CYII="
else if percentage is greater than or equal to 16 and percentage is less than or equal to 25 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtUlEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XVlIdqVcaCBvE1gII+ZBOaLZDKZvwZDg8MTg2egwWzVFRNnMXEL5RboqCijpi+p6AAblh1wPeV5L8AQljxQitB/h+sPdw8+LAHruXK49+3d5OS8aLlryQFGaj05tJryWVNOsvI50Q8dMTryNy112rtlv3Kf561c1bBYY66IEhe/Y04zoEUwWBxLlHbBYXlIJpNJhg+ixOhuQfsw9wAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 10 and percentage is less than or equal to 15 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtElEQVR42u2VvQqDMBRGL/oepSkU0wc3m4PPYJ/FjNo6x9OhCI24xQsN5CwJ33DID9xPpFAo/DVYWjyBFAIjLXavNsycxcwtljugx1An3b7G0AMujj1wPeV5L8AYRwGoRRiAIfH0EOII2NbvLkG/N2Qn50XHXUsOMNHoyaHTlC+acrKVL5l+6ITVkb/paPKeLb8j93n2yFUti63mqiRxdVxzmgUtgsXhWZO0Kx7HQwqFQjZ8AFyxiM55BDSUAAAAAElFTkSuQmCC"
else if percentage is less than 10 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAA10lEQVR4Ae3YMQ6CQBCFYQL3MGpiWE9g6WndjoLjWNpAiWq9jFM82rGcHfMm+RMLik8zBpZGREJGOOGEu0Y44YQn7abNWhG/KdoES/oFP2hPqWxgOlrwjAtHfInOcQU6GEaYsgWfcdG+oh3ewTQZcOw0fun79fKoAN7BVCz4Ng3g+OwehnA3+EsbtFM0+DaL1oeDY4ao8E9UuPwxnKvCP+eipUjwN25APW/5XvCwj7WBDhL20a11BLf20S3iYdl4PZGxNqsjdoUha2e+ySKc8AARTjjhQfoCLEebqfw1Zu4AAAAASUVORK5CYII="
end if
else if charging is "charging" or charging is "AC" then
set timeremaining to ""
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
end if
else if charging is "charged" then
set batteryIcon to "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"
set percentage to 100
end if
UPDATE:
I found the solution, you have to input the following return statement to display the info on two lines:
return "{\"text\":\"" & percentage & "%" & "\\n" & timeremaining & "\", \"icon_data\":\"" & batteryIcon & "\"}"
We will collect all the research information required to widgets development/improvement
Sub-topics
Problem: Current btt widget Touch Bar iStats needs istats ruby gem. Use macOS native util, no 3rd party installation.
Solution: powermetrics
sudo powermetrics --show-all
All sensors data, natively
WIP v0.0.1: https://github.com/marekkaczkowski/Touch-Bar-CSGO-HUD
Problem: Proxy data to BetterTouchTool and update widget without Node.js
Solution:
Connected feature request: 9676
Diffrent ways of integration:
That terminal command is an amazing find. Will report back this evening after I’ve had the chance to take a deep dive
Hey guys here is first version of Counter-Strike: Global Offensive HUD.
It requires to run Node.js proxy,
we're looking for the solution to get rid of 3rd party dependencies.
Turns out power metrics needs to be invoked as sudo, which means I can't use it for the widget. Gonna do some more research...
from your last update I presume that Battery stats are high on your list?
Use the following command:
ioreg -w 0 -f -r -c AppleSmartBattery
Result:
+-o AppleSmartBattery <class AppleSmartBattery, id 0x1000002cd, registered, matched, active, busy 0 (0 ms), retain 6>
"TimeRemaining" = 138
"ExternalConnected" = No
"AvgTimeToEmpty" = 138
"AppleRawCurrentCapacity" = 5944
"InstantTimeToEmpty" = 65535
"AppleRawMaxCapacity" = 6113
"ExternalChargeCapable" = No
"FullPathUpdated" = 1564428995
"CellVoltage" = (4305,4306,4305,0)
"Voltage" = 12253
"BatteryInvalidWakeSeconds" = 30
"AdapterInfo" = 0
"MaxCapacity" = 6113
"PermanentFailureStatus" = 0
"DesignCycleCount70" = 0
"Manufacturer" = "SMP"
"AppleRawAdapterDetails" = ()
"Location" = 0
"CurrentCapacity" = 5944
"LegacyBatteryInfo" = {"Amperage"=18446744073709549023,"Flags"=4,"Capacity"=6113,"Current"=5944,"Voltage"=12253,"Cycle Count"=251}
"BatteryFCCData" = {"ResScale"=200}
"BatteryInstalled" = Yes
"FirmwareSerialNumber" = 1
"CycleCount" = 251
"PackReserve" = 200
"DesignCapacity" = 6669
"OperationStatus" = 58435
"ManufactureDate" = 19050
"BestAdapterIndex" = 254
"AvgTimeToFull" = 65535
"BatterySerialNumber" = "D867105E2ZBHDWCAN"
"BootPathUpdated" = 1564177670
"ChargerData" = {"ChargingVoltage"=13048,"ChargingCurrent"=0,"NotChargingReason"=1}
"PostDischargeWaitSeconds" = 120
"Temperature" = 3011
"BatteryData" = {"StateOfCharge"=98,"PMUConfigured"=0,"Voltage"=12691,"QmaxCell1"=6778,"AdapterPower"=0,"SystemPower"=4425,"ResScale"=200,"QmaxCell2"=6769,"QmaxCell0"=6768,"CycleCount"=251,"DesignCapacity"=6669}
"UserVisiblePathUpdated" = 1564429355
"IOReportLegendPublic" = Yes
"InstantAmperage" = 18446744073709548794
"FullyCharged" = Yes
"ManufacturerData" =
00000000: 00 00 00 00 07 02 00 01 39 25 00 00 03 35 38 30 03 30 30 32 03 41 54 4C 01 3C 00 ........9%...580.002.ATL.<.
"DeviceName" = "bq20z451"
"MaxErr" = 1
"IOGeneralInterest" = "IOCommand is not serializable"
"IOReportLegend" = ({"IOReportChannels"=((7167869599145487988,6460407809,"BatteryCycleCount")),"IOReportGroupName"="Battery","IOReportChannelInfo"={"IOReportChannelUnit"=0}})
"Amperage" = 18446744073709549023
"IsCharging" = No
"DesignCycleCount9C" = 1000
"PostChargeWaitSeconds" = 120
"AdapterDetails" = {"FamilyCode"=0}
I'm not aware of any way to get temperature or fan speed without sudo or a 3rd party tool in terminal, but maybe @Andreas_Hegenberg could add smc-command capabilities and provide the information in some builtin variables?
A way to get current battery percentage: pmset -g batt | grep -m 1 - | cut -d ' ' -f 3 | cut -d$'\t' -f 2 | sed 's/.$//'
Does anyone know how to get CPU usage percent (out of 100%), total memory, and available memory? I'm having a hard time finding a preexisting top
command for these outputs.
EDIT: Making progress by learning how to use grep
lol
CPU (due to multicore not quite straight forward):
ncpu=$(sysctl -n hw.logicalcpu)
total=$(ps -Ao %cpu= | paste -sd+ - | bc)
usage=$(echo "scale = 2; $total / $ncpu" | bc)
printf "%0.1f%%\n" "$usage"
Total Memory: sysctl hw.memsize
Used: top -l 1 -s 0 | grep PhysMem
The battery information could also be retrieved using Objective-C methods.
@GoldenChaos - could you make it so that clicking the memory button will clean the memory? Just like 3rd party apps can?
I don't think those "free up memory" tools are doing something I can invoke with a simple terminal command - but I can look into it!
Thanks for responding! I appreciate it!
Free up memory tools just fill up the memory until the system cleans it. There is no use in them (just placebo). The system will automatically free up memory if necessary.
ahhh... thanks for informing me!
Also, @Andreas_Hegenburg, could you check my bug report? Sadly no one has actually responded to my bug report
To add to the responses above. The following available in the link below:
