Battery + System Stats widgets development thread
Good find. I added battery temperature information to thread I linked in here earlier.
It's coming along! Icons are just placeholder while I figure out the optimal layout...
That's weird. Are you getting the negative download throughput naturally?
Yep. Was wondering about that...
Hi ! Thank you for your great work!
  1. I unchecked "Show Percentage" and "Remaining Time" But it still shows remaining time.
is there any way to fix ?
I just bought this app yesterday !
That option only affects the menu bar widget - the long-press stats group doesn't have any configurable settings!
Hi everyone,
does anyone know if it's possible to have the battery icon on top and the time remaining underneath? Somethine like this:
Touch Bar Shot 2020-05-29 at 12.30.21
Very nice development here!
My MacBook just hard-restarted, I think because it got too hot (was on a pillow), so I was wondering if there was any way to display the CPU (or other temperature) on the Touchbar.
It sounds like this is not simple to do, and not included or planned to be added to this neat widget.
What do you think?
Hi there,
I'm trying to do the same thing but only with the icon and the percentage underneath it.
I can't for the life go me get it to work!
@GoldenChaos is it even possible?
BTW thanks for your amazing work! Love it !
