I've been experiencing a bug in the last couple updates where several of my scripts don't seem to work, and restarting BTT doesn't seem to fix it (it just seems to go away after several minutes). I'm not sure if this is due to the latest MacOS update, or BTT, but it's causing my touch bar to be totally thrown off. It seems to occur after coming out of sleep. I've attached screenshots below, please fix this it's super annoying!
Touch bar
Bug: (see icons on the right side, D/T and volume aren't working)
What it should look like:
- Type of Mac: MacBook Pro 15" 2017
- macOS version: 10.14.4
- BetterTouchTool version: 2.754
