Battery Indicator on Touch Bar is compacted and overlapping
With the battery indicator touch bar widget, the battery icon and the remaining time is usually pressed together when the BTT bar is opened. The issue fixes itself within a couple of seconds, but the issue is consistent and is not permanently fixed. (Video of bugged icon attached to hopefully reduce confusion)
Affected device is Touch Bar.
  • Type of Mac: 13-inch 2019 Macbook Pro with 2 Thunderbolt Ports
  • macOS version: 10.14.6 (Mojave)
  • BetterTouchTool version: 3.202 (1378)
Video of bug:
I confirm this issue.
Interestingly it does not always behave like that, I wonder what it makes "fall asleep".
Here's some charge (not time)-remaining script for an Apple Script Widget replacement for the Remaining Battery Time Widget. The RBTW icon is so ugly anyway.
set batteryStatus to do shell script "pmset -g batt"
set powerSource to word 4 of batteryStatus
set percentage to word 11 of batteryStatus as integer
set charging to word 12 of batteryStatus
if charging is "discharging" then
if percentage is greater than or equal to 96 and percentage is less than or equal to 100 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAs0lEQVR42u2WQQrDIBBFh3iP0hRK7MHjLoucIT1LXCZt1uZ1FaglOx2o4NsIs3jgCP8rUqlU/hosPZ5ACoGZHvurblnJxcotljtgpMUk3d7QMgIuHnvgmmW9F2CORwEwIkxJC5lEMECI5cBxpvDtKlfOi4G7lhxgodOTw6Ap3zTlFCvfCn3QBasjfzPQlZ0teSL3eR65qmVx1FyTJG7Oa06zoEWwODx7knbH43jUj1qlUg4fxZ8lasabhQ4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 86 and percentage is less than or equal to 95 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2WQQqDMBBFg96jNIVienCzy8Iz2LOYpbau4+tKaGzpwjjQQN4mMItHMgPzo1ShUPhrMLR4AikEBlrMVq2ZOIqJSyy3QIemTnp9jaYDbFz2wPmQ9p6AIS4FoFaKfmcr+rfbQ4jlwHru49OVr5wHjquUHGCkkZODk5TPknKylc+ZDnTEyMifOJq8d0vqyr3/WrmiYbHGXJUkrr7HnGRAK4XB4lmStAsey6181AqFfHgB7SnFu8OCs/4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 76 and percentage is less than or equal to 85 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQqDMBBFg96jNIVienCzc+EZ7FnMUlvX8XXlIioUGwcayNsEZvGYTGB+lMpkMn8NhhqHJwZPT41ZqzUjZzFyC+UWaNGUUbcv0bSADcsOuJ4y3gvQhyUPlErRHR5Ct+kefFgClvMom97XteTkvGi4S8kBBio5OTSS8klSTrLyKdEHHTAy8jcNVdq75feV+/y+ckXDYom5Ikpc7MecZEArhcHimKO0Mw7LI3/UMpl0+ADW1WYbk5lWXgAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 66 and percentage is less than or equal to 75 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJblHqYUSe/C4yyJnSM8Sl0mbtXldZWFowGIGKvg2wgiPUWG+ShUKhb8GQ4vDk4JnpMXs1ZqZs5i5hXIL9GjqpNPXaHrAhmUHXE+53gswhiUP1EoxRB9+OOwefFgCtjWWw973e9nJedFxl5IDTDRycugk5YuknGzlS6YPOmFk5G86mrxny+8j9xk/ckXDYou5KklcfY85yYBWCoPFsSZpVxyWR/moFQr58AGRs+aMzl3kdAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 56 and percentage is less than or equal to 65 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJd6j1EKJPXjcZZEzpGeJy6TN2ryusjAU0mAGKvg2wiCPUWG+ShUKhb8GS4MnkEJgoMFu1YaJs5i4xXIHdBh00uk1hg5wcdkD11Ou9wIMcSkAWin6H47d73QPIS4B67rPTu/bHdnJedFyl5IDjNRycmgl5bOknGzlc6YPOmJl5G9a6rxny5GR+zw6ckXDYo25KklcfY85yYBWCovDsyRpFzyOR/moFQr58AFAVIbsiXp9RAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 46 and percentage is less than or equal to 55 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlIlJEGgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj97sD9oe7BhyVgPfc41Pv2XnJyXrTcteQAI7WeHFpN+awpJ1n5nOiHjhgd+ZuWOu3dcmzlPn9buaphscZcESUuvsecZkCLYLA4lijtgsPykEwmkwwfsQgnTIxdnPMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 36 and percentage is less than or equal to 45 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlImIpEgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj9l1H7A92DD0vAeu5zoPft7eTkvGi5a8kBRmo9ObSa8llTTrLyOdEPHTE68jctddq75dfKfcasXNWwWGOuiBIX+zGnGdAiGCyOJUq74LA8JJPJJMMH497HnQsmWpMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 26 and percentage is less than or equal to 35 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlItouJA40kLcJDOQxk8B8kUwm89dgaHB4YvAMNJitumLiLCZuodwCHRVl1PQlFR1gw7IDrqc87wUYwpIHShH63ZD94e7BhyVgPbcc7n17Jzk5L1ruWnKAkVpPDq2mfNaUk6x8TvRDR4yO/E1LnfZu+b1yn/ErVzUs1pgrosTF95jTDGgRDBbHEqVdcFgekslkkuED2NZn/WdIKR8AAAAASUVORK5CYII="
else if percentage is greater than or equal to 16 and percentage is less than or equal to 25 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtUlEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XVlIdqVcaCBvE1gII+ZBOaLZDKZvwZDg8MTg2egwWzVFRNnMXEL5RboqCijpi+p6AAblh1wPeV5L8AQljxQitB/h+sPdw8+LAHruXK49+3d5OS8aLlryQFGaj05tJryWVNOsvI50Q8dMTryNy112rtlv3Kf561c1bBYY66IEhe/Y04zoEUwWBxLlHbBYXlIJpNJhg+ixOhuQfsw9wAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 10 and percentage is less than or equal to 15 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtElEQVR42u2VvQqDMBRGL/oepSkU0wc3m4PPYJ/FjNo6x9OhCI24xQsN5CwJ33DID9xPpFAo/DVYWjyBFAIjLXavNsycxcwtljugx1An3b7G0AMujj1wPeV5L8AYRwGoRRiAIfH0EOII2NbvLkG/N2Qn50XHXUsOMNHoyaHTlC+acrKVL5l+6ITVkb/paPKeLb8j93n2yFUti63mqiRxdVxzmgUtgsXhWZO0Kx7HQwqFQjZ8AFyxiM55BDSUAAAAAElFTkSuQmCC"
else if percentage is less than 10 then
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAA10lEQVR4Ae3YMQ6CQBCFYQL3MGpiWE9g6WndjoLjWNpAiWq9jFM82rGcHfMm+RMLik8zBpZGREJGOOGEu0Y44YQn7abNWhG/KdoES/oFP2hPqWxgOlrwjAtHfInOcQU6GEaYsgWfcdG+oh3ewTQZcOw0fun79fKoAN7BVCz4Ng3g+OwehnA3+EsbtFM0+DaL1oeDY4ao8E9UuPwxnKvCP+eipUjwN25APW/5XvCwj7WBDhL20a11BLf20S3iYdl4PZGxNqsjdoUha2e+ySKc8AARTjjhQfoCLEebqfw1Zu4AAAAASUVORK5CYII="
end if
else if charging is "charging" or charging is "AC" then
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAACGElEQVR4Ae2YA4xeURCFa7dRbTOorRg149q2jahRjai2bds2gnpt42xy/mSiu7nvzfpO8i1nzv89o1BaWlqexIk7cSeeozhxJ+7Em4J94A9IAX7qtfiAtqACfw4HxuJn/6ZL08zE6zFUo96AVgyfCDaBIvw92SaITvVN4vvZeIoLUZT/9ENHZra2nCtKh1Oc328S/8Omukr7XynmPfORUZsZvw3i3Ke5pnt/GnMHpFmyQYQ+Y15b5k0Dd6zXPPd5gziLf/AgfVEEHmLWV2bVZw/zrWApi5M3oCRnV4usicwanhvFP4AWnBsFZJVn1mtF8QhwDDTyIx4CenKmO5C1hTmVJArigQoDTbyKD2V/PZAkMlJBR7OQP3HWMS/is8Vp7xdnpfh38Bf8k/D/a5TEo2zFV4qghx6uqiWVxNNsxG+KkMuW0p9BYc5mu/ga9ixmfwyIFkRxl0gFsqJAFeV9PMp+jZtpJ8VZbXPDwXkTdGVfaVAmAOeXA1mD2NtO+XTYVOOS/4uzxUCsyJvPvMrgjYJ4JC9ATbTuVWZwdqjI2iHy7ua6exXShrNPmHNNZO3SueTr39auZVADZvwQ0stE313921qdB4nzzKhq6FF4kDA/uhWx/JD6nO+nIFzE/Oim87A8nCHrwFL+XB28MY/pPSxn0JRL90deQAwVzbkyoIsIvO5TNhX8oUsz9ybLiTtxJ+7EnbgT1yId5lN9u+XAf4cAAAAASUVORK5CYII="
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
	set batteryIcon to "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"
end if
else if charging is "charged"
set percentage to 100
end if
return "{\"text\":\"" & percentage & "%\", \"icon_data\":\"" & batteryIcon & "\"}"
Great, right there full example of pmset commands and how to extract single data.
I did always use regexes (ugly)
Thanks a bunch for this!
Used your widget but am seeing that the icon moves a bit to the left after a few seconds thereby creating more space between the battery percentage and the icon. Quite annoying. Are you seeing this too?
I'm on it, will be fixed with the next BTT.
