Hey,
does anyone else have also the issue that as soon as activating GC the Battery usage is very high?
thanks..
Hey,
thanks..
Since the last update this preset is unsuble for me. It produces high system loads, my Macbook Pro is nearly unusable. According to iStat Menus the load goes up to ~10-15. After quitting BTT it goes down again. Tested it several times with nothing else running. I'm waiting for the next update and will try it again.
thank you for your answer.. So I am not alone with this issue.
