I don't find this function and I know if that exist, but a good idea is to change the color of batteries icon (or background) in the Touch Bar in function of the charge %.
For example, to have the possibilities to colorize the background in red if the batteries is less or equal of 20%, orange less or equal 40% and green between 100 and 40%
I made custom script for this.. its based on icons/scripts used in GoldenTouch bar extension.
Down the script you can tune if to show percentage also or not.
set batteryStatus to do shell script "pmset -g batt"
set powerSource to word 4 of batteryStatus
set percentage to word 11 of batteryStatus as integer
set charging to word 12 of batteryStatus
if charging is "discharging" then
if percentage is greater than or equal to 96 and percentage is less than or equal to 100 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAs0lEQVR42u2WQQrDIBBFh3iP0hRK7MHjLoucIT1LXCZt1uZ1FaglOx2o4NsIs3jgCP8rUqlU/hosPZ5ACoGZHvurblnJxcotljtgpMUk3d7QMgIuHnvgmmW9F2CORwEwIkxJC5lEMECI5cBxpvDtKlfOi4G7lhxgodOTw6Ap3zTlFCvfCn3QBasjfzPQlZ0teSL3eR65qmVx1FyTJG7Oa06zoEWwODx7knbH43jUj1qlUg4fxZ8lasabhQ4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 86 and percentage is less than or equal to 95 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2WQQqDMBBFg96jNIVienCzy8Iz2LOYpbau4+tKaGzpwjjQQN4mMItHMgPzo1ShUPhrMLR4AikEBlrMVq2ZOIqJSyy3QIemTnp9jaYDbFz2wPmQ9p6AIS4FoFaKfmcr+rfbQ4jlwHru49OVr5wHjquUHGCkkZODk5TPknKylc+ZDnTEyMifOJq8d0vqyr3/WrmiYbHGXJUkrr7HnGRAK4XB4lmStAsey6181AqFfHgB7SnFu8OCs/4AAAAASUVORK5CYII="
else if percentage is greater than or equal to 76 and percentage is less than or equal to 85 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQqDMBBFg96jNIVienCzc+EZ7FnMUlvX8XXlIioUGwcayNsEZvGYTGB+lMpkMn8NhhqHJwZPT41ZqzUjZzFyC+UWaNGUUbcv0bSADcsOuJ4y3gvQhyUPlErRHR5Ct+kefFgClvMom97XteTkvGi4S8kBBio5OTSS8klSTrLyKdEHHTAy8jcNVdq75feV+/y+ckXDYom5Ikpc7MecZEArhcHimKO0Mw7LI3/UMpl0+ADW1WYbk5lWXgAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 66 and percentage is less than or equal to 75 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJblHqYUSe/C4yyJnSM8Sl0mbtXldZWFowGIGKvg2wgiPUWG+ShUKhb8GQ4vDk4JnpMXs1ZqZs5i5hXIL9GjqpNPXaHrAhmUHXE+53gswhiUP1EoxRB9+OOwefFgCtjWWw973e9nJedFxl5IDTDRycugk5YuknGzlS6YPOmFk5G86mrxny+8j9xk/ckXDYou5KklcfY85yYBWCoPFsSZpVxyWR/moFQr58AGRs+aMzl3kdAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 56 and percentage is less than or equal to 65 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAuElEQVR42u2WQQrDIBBFJd6j1EKJPXjcZZEzpGeJy6TN2ryusjAU0mAGKvg2wiCPUWG+ShUKhb8GS4MnkEJgoMFu1YaJs5i4xXIHdBh00uk1hg5wcdkD11Ou9wIMcSkAWin6H47d73QPIS4B67rPTu/bHdnJedFyl5IDjNRycmgl5bOknGzlc6YPOmJl5G9a6rxny5GR+zw6ckXDYo25KklcfY85yYBWCovDsyRpFzyOR/moFQr58AFAVIbsiXp9RAAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 46 and percentage is less than or equal to 55 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlIlJEGgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj97sD9oe7BhyVgPfc41Pv2XnJyXrTcteQAI7WeHFpN+awpJ1n5nOiHjhgd+ZuWOu3dcmzlPn9buaphscZcESUuvsecZkCLYLA4lijtgsPykEwmkwwfsQgnTIxdnPMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 36 and percentage is less than or equal to 45 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlImIpEgcayNsEhvCYSWC+SCaT+WswNDg8MXgGGsxWXTFxFhO3UG6BjooyavqSig6wYdkB11Oe9wIMYckDpQj9l1H7A92DD0vAeu5zoPft7eTkvGi5a8kBRmo9ObSa8llTTrLyOdEPHTE68jctddq75dfKfcasXNWwWGOuiBIX+zGnGdAiGCyOJUq74LA8JJPJJMMH497HnQsmWpMAAAAASUVORK5CYII="
else if percentage is greater than or equal to 26 and percentage is less than or equal to 35 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtklEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XXlItouJA40kLcJDOQxk8B8kUwm89dgaHB4YvAMNJitumLiLCZuodwCHRVl1PQlFR1gw7IDrqc87wUYwpIHShH63ZD94e7BhyVgPbcc7n17Jzk5L1ruWnKAkVpPDq2mfNaUk6x8TvRDR4yO/E1LnfZu+b1yn/ErVzUs1pgrosTF95jTDGgRDBbHEqVdcFgekslkkuED2NZn/WdIKR8AAAAASUVORK5CYII="
else if percentage is greater than or equal to 16 and percentage is less than or equal to 25 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtUlEQVR42u2VQQqDMBBFB71HqYVienCzc+EZ7FnMUlvX8XVlIdqVcaCBvE1gII+ZBOaLZDKZvwZDg8MTg2egwWzVFRNnMXEL5RboqCijpi+p6AAblh1wPeV5L8AQljxQitB/h+sPdw8+LAHruXK49+3d5OS8aLlryQFGaj05tJryWVNOsvI50Q8dMTryNy112rtlv3Kf561c1bBYY66IEhe/Y04zoEUwWBxLlHbBYXlIJpNJhg+ixOhuQfsw9wAAAABJRU5ErkJggg=="
else if percentage is greater than or equal to 10 and percentage is less than or equal to 15 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAQAAACweEK3AAAAtElEQVR42u2VvQqDMBRGL/oepSkU0wc3m4PPYJ/FjNo6x9OhCI24xQsN5CwJ33DID9xPpFAo/DVYWjyBFAIjLXavNsycxcwtljugx1An3b7G0AMujj1wPeV5L8AYRwGoRRiAIfH0EOII2NbvLkG/N2Qn50XHXUsOMNHoyaHTlC+acrKVL5l+6ITVkb/paPKeLb8j93n2yFUti63mqiRxdVxzmgUtgsXhWZO0Kx7HQwqFQjZ8AFyxiM55BDSUAAAAAElFTkSuQmCC"
else if percentage is less than 10 then
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAA10lEQVR4Ae3YMQ6CQBCFYQL3MGpiWE9g6WndjoLjWNpAiWq9jFM82rGcHfMm+RMLik8zBpZGREJGOOGEu0Y44YQn7abNWhG/KdoES/oFP2hPqWxgOlrwjAtHfInOcQU6GEaYsgWfcdG+oh3ewTQZcOw0fun79fKoAN7BVCz4Ng3g+OwehnA3+EsbtFM0+DaL1oeDY4ao8E9UuPwxnKvCP+eipUjwN25APW/5XvCwj7WBDhL20a11BLf20S3iYdl4PZGxNqsjdoUha2e+ySKc8AARTjjhQfoCLEebqfw1Zu4AAAAASUVORK5CYII="
end if
else if charging is "charging" or charging is "AC" then
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "iVBORw0KGgoAAAANSUhEUgAAAC4AAAAsCAYAAAAacYo8AAAB+0lEQVR4Ae2YA6wdURRFa7dxbSOorRg145pRbStqVCNOatu2bQblt639k/2S8zUvd+bM5z3JerxnzxqjXGZmZonEiltxK16kWHErbsXbg/3gL0gHXuqNmEB3UIefo4I1ctp/6NI+mHgLhmrUW9CF4bPBdlCB39NMgujU0kn8AAee5kxUVFiVvZnZ1bCvIh1Os/+Ak/hfDmqutP1VY95zDxlNmfHHQZzbNJf00M/T7oJMQ7aK0OfM6+5BvCIz0h3EWfzBhfQlEXiYWd8U1hzLH/G3oCp7N4is2cVZ/CPoxL4pQFZtH8SjwXHQxot4OBjMnoFA1k7+ri0eqEjQzq34eI5vAVJFRgbo7ac467gb8QXisPebvVL8B/gH/kv4/0Yl8VhT8XUi6JGLs2pVJfFME/FbIuSKofQXUJ69hS4eWM0rOD4exAliuUlkAFmxoJ7yNh5rvsSd6ZGPePfisHPeAv05rjqoEYD9a4CsMT4dDttrnPJ/s7cSSBB5S5QPhzE8AbXTulaZy97xImtvsb5WId3Y+5Q51/VPQPqXtZsY1IoZP2W4/mWt/o3EBWbUVxEXNxImt24VDCfSkv0jFIQrON+66dwsT2TIZrCKnxuCt85tejfL2bQHB7jZZIBgFce+GqCfCLzhUTaDDgdAB/sky4pbcStuxa24FdciC4Vak2WaD0PuAAAAAElFTkSuQmCC"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
set batteryIcon to "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"
end if
else if charging is "charged" then
set percentage to 100
end if
set colorScale to (100 - percentage) / 100
if colorScale ≤ 0.5 then
set redColorIndex to round (colorScale * 2 * 255)
set greenColorIndex to 255
else
set redColorIndex to 255
set greenColorIndex to round(2 * 255 - (colorScale * 2 * 255))
end if
if percentage > 0 then
return "{\"font_color\": \"" & redColorIndex & "," & greenColorIndex & ",0,255\", \"text\":\"" & percentage & "%\", \"icon_data\":\"" & batteryIcon & "\"}"
else
return "{\"font_color\": \"100,200,100,255\", \"text\":\"" & percentage & "%\", \"icon_data\":\"" & batteryIcon & "\"}"
end if
else
return "{\"fontColor\":\"none\", \"text\":\" \", \"icon_data\":\"" & batteryIcon & "\"}"
end if
