Background color for Menu Icon Floating Window not respecting selection
Trying out the preset demo of the floating menubar icons, which works as advertised. But, I tend to stay in light mode, and want a bright background in the floating-menu for the popup bar, similar to my system menu bar settings. I set the opacity to 1 and the background color to solid white, also to hover with solid white, yet the background remains mid-grey. I also made sure that "Show Shadow" is disabled. Enclosed is screenshot, showing the dim-grey floating menu preview plus the lighter system menu. Am I missing a setting?
Note:
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
