Azure Data Studio Click/Mouse Movement issues
Using a MacBook Pro with MacOS 12.2.1 and BTT version 3.75(1897)
I notice when using Azure Data Studio, after some time, the mouse movements become laggy and erratic. Then it seem "Click lock" will randomly turn on and instead of selecting objects I end up dragging things around that are unintentional. I am using with a Logitech MX Master wireless mouse.
Activity monitor shows BTT as my highest cpu utilization (37+%) during this behavior.
When I restart BTT, the lagginess of the mouse goes away and the clicking is back to normal.
  • Type of Mac:
  • macOS version:
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
