Auto copy when highlight
How do I achieve —when I highlight anything text/s in any app, I want BTT to auto copy it
Thanks
you can use the Text Selection Did Change trigger - it will also automatically save the selected text to a BTT variable:
exported_triggers.bttpreset (1.8 KB)
I have this but it only works if I actually press the “run the script” other wise it doesn’t work. how do i enable to outrun when I highlight a text
