The last version (2.687 [992]) messed up my Touch Bar settings.
Now the Global Shortcut (available system wide) are intermixed with application-specific ones. On the attached screenshot, the arrows, envelop, battery, histogram, THL icons are "systemwide" and should be packed on the left of the TouchBar while the colored buttons are specific the the Mail application and should be on the right. In addition, in the previous version, only the Application-Specific icons were scrollable (when too many) while here everything is scrolling when touching the bar.
MacBookPro Trackpad
- Type of Mac:
MacBookPro 2017 - macOS version:
Mojave 10.14.2 - BetterTouchTool version:
2.687 [992]
