Use case: Productivity improvement
Feature request: On application launch position window in default area, and monitor (such as a snap area)
Expanded. I frequently work with multiple windows e.g. One to two Finder Windows, Browser sessions (one to two) etc. I always position these windows in similar layout. I wish there was a hotkey I could press to position windows and / or even better, when I open them they position in the right location (monitor and position) automatically.
ADVANCED: Multi window support. For e.g. When you open second, third and more instances of an application (e.g. finder) you would want to use primary location, secondary location, third location so that when one space is already used by the same app, the secondary location is used.
Hope this helps
