applescript not updating, weird button icon shift and appearance
hello,
i am running 3.335 and my apple scripts are not updating too. apart from that, the icon on my play/pause button strangely shifted from being centered on the button to some place on the left. i had to adjust by changing the padding.
last but not least, the weather widget started to show colored icons which are not set in BTT.
here are the scripts for the buttons that are „broken“
button to toggle true tone (changes color and icons, when truetne is enabled):
(button itself works finde, the icons dont always show up)
set trueToneState to is_true_tone_enabled
end tell
script that displays a warning icon, when true tone is enabled:
(works fine, when i turn on true tone. doesnt go away, when i turn of true tone even though it is set to a 5 seconds refresh rate)
end tell
any ideas?
cheers
You stated that the first script toggles true tone, yet there is only one line that does anything, and it appears to be retrieving the state of true tone, as a true or false value, but doesn't seem to do anything with it. The second script, which is identical to the first, is then stated as displaying a warning icon if true tone is enabled, but I can't see how that's being achieved. Also, what is is_true_tone_enabled ? Is it a built-in property provided by Better Touch Tool, or are these two scripts incomplete?
yes, these are built in scripts by btt.
the true tone button is a script widget with a "button" as an action attached to it like so:
and here is a video of the button which shows, that the icon only shows up, once i pressed the button.
the warning icon is a script widget as well, which shows an icon, when the value is true, and doesnt show an icon, when the value is false.
it is weird that it turns on the warning icon, when i active true tone, but doesnt go away, when i turn it off...
i think i know why the weather widget displayed an icon that i never set. i wasnt connected to the internet so it couldnt receive the weather data and just displayed a default icon for "night" rather than my custom icons?
With your configuration it should turn off after 5 seconds when the script runs again after tapping the butotn.
To run the script again right after tapping the button you'd need to use the refresh_widget function.
Also you should add an explicit return. While implicit return works in Apple Script sometimes, it can cause weird errors.
Here is an example (copy & paste right into the BTT main window):
    "BTTWidgetName" : "toggle true tone",
    "BTTTriggerType" : 639,
    "BTTTriggerTypeDescription" : "Apple Script \/ JavaScript Widget",
    "BTTTriggerClass" : "BTTTriggerTypeTouchBar",
    "BTTPredefinedActionType" : 257,
    "BTTPredefinedActionName" : "Toggle True Tone (only on supported systems)",
    "BTTEnabled2" : 1,
    "BTTRepeatDelay" : 0,
    "BTTUUID" : "A76DDDEF-4CA9-41A2-993B-7595CF534970",
    "BTTEnabled" : 1,
    "BTTModifierMode" : 0,
    "BTTOrder" : 3,
    "BTTDisplayOrder" : 0,
    "BTTMergeIntoTouchBarGroups" : 0,
    "BTTAdditionalActions" : [
        "BTTTriggerType" : -1,
        "BTTPredefinedActionType" : 129,
        "BTTPredefinedActionName" : "Delay Next Action",
        "BTTDelayNextActionBy" : "0.3",
        "BTTEnabled2" : 1,
        "BTTAlternateModifierKeys" : 0,
        "BTTUUID" : "3E7AD2FF-DA72-46FB-8AC4-7104927E017C",
        "BTTEnabled" : 1,
        "BTTOrder" : 0,
        "BTTPredefinedActionType" : 195,
        "BTTPredefinedActionName" : "Run Apple Script (async in background)",
        "BTTInlineAppleScript" : "tell application \"BetterTouchTool\"\r\trefresh_widget \"A76DDDEF-4CA9-41A2-993B-7595CF534970\"\rend tell\r",
        "BTTEnabled2" : 1,
        "BTTUUID" : "DC2184F0-296D-4B29-A0A1-5FD66A38EBFC",
        "BTTEnabled" : 1,
        "BTTOrder" : 1,
    "BTTIconData" : "TU0AKgAAQAj\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAYAAAAIAAAADAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAADAAAAAgAAAAGAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADgAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAOAAAACgAAAAUP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAACAAAAA4AAAAP8AAAD\/AAAA\/wAAAP8AAADAAAAAgAAAAGAAAABAAAAAIP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAQAAAAGAAAACAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAADgAAAAgAAAACD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAKAAAAD\/AAAA\/wAAAP8AAADwAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADwAAAA\/wAAAP8AAAD\/AAAAoAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAPAAAAD\/AAAA\/wAAAMAAAABg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADAAAAA\/wAAAP8AAADwAAAAgP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA0AAAAP8AAAD\/AAAAwAAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAEAAAADAAAAA\/wAAAP8AAADQAAAAMP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADwAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAP8AAACwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAALAAAAD\/AAAA\/wAAAKD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAcAAAAP8AAAD\/AAAA0AAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAPAAAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA8AAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADQAAAA\/wAAAPAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAADAAAADwAAAA\/wAAAND\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAPAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAMAAAAPAAAAD\/AAAAoP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAHAAAAD\/AAAA\/wAAADD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA0AAAAP8AAACw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAsAAAAP8AAADQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAPAAAAD\/AAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAwP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAKD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAAD\/AAAA\/wAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAP8AAAD\/AAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACAAAAA\/wAAAMD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA4AAAAP8AAABg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADg\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADwAAAA\/wAAAFD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAkP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAACg\/\/\/\/AP\/\/\/wAAAADgAAAA\/wAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAFAAAAD\/AAAA4P\/\/\/wAAAAAgAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAAgAAAAYAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAMAAAAD\/AAAAYAAAAIAAAAD\/AAAAgP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACAAAAA\/wAAAIAAAADAAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADAAAAAwAAAAP8AAABA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAEAAAAD\/AAAAwAAAAP8AAAD\/AAAAIP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAA\/wAAAP8AAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/AAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/wAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/AAAA\/wAAAP8AAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAAD\/AAAA\/wAAAMAAAAD\/AAAAQP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABAAAAA\/wAAAMAAAADAAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADAAAAAgAAAAP8AAACA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAIAAAAD\/AAAAgAAAAGAAAAD\/AAAAwP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAGAAAAAgAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAAg\/\/\/\/AAAAAOAAAAD\/AAAAUP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADg\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAJD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAoP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADwAAAA\/wAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADgAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABgAAAA\/wAAAOD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAwAAAAP8AAACA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAAD\/AAAA\/wAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAP8AAAD\/AAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAMAAAAD\/AAAAoP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAAD\/AAAA8AAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADQAAAA\/wAAALD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACwAAAA\/wAAAND\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAMAAAAP8AAAD\/AAAAcP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAA8AAAADD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA8AAAAP8AAACg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA0AAAAP8AAADwAAAAMP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA8AAAAP8AAADQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAPAAAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA8AAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAANAAAAD\/AAAA\/wAAAHD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAAD\/AAAAsAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAACwAAAA\/wAAAP8AAACg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADwAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAADAAAADQAAAA\/wAAAP8AAADAAAAAQP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAMAAAAD\/AAAA\/wAAANAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAIAAAADwAAAA\/wAAAP8AAADAAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABgAAAAwAAAAP8AAAD\/AAAA8AAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAKAAAAD\/AAAA\/wAAAP8AAADwAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADwAAAA\/wAAAP8AAAD\/AAAAoAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAIAAAAIAAAADgAAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAACAAAAAYAAAAEAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAABAAAAAYAAAAIAAAADAAAAA\/wAAAP8AAAD\/AAAA\/wAAAOAAAACAAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAFAAAACgAAAA4AAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADgAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAYAAAAIAAAADAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAADAAAAAgAAAAGAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AABABAAADAAAAAQBAAAABAQADAAAAAQBAAAABAgADAAAABAAAQM4BAwADAAAAAQABAAABBgADAAAAAQACAAABCgADAAAAAQABAAABEQAEAAAAAQAAAAgBEgADAAAAAQABAAABFQADAAAAAQAEAAABFgADAAAAAQBAAAABFwAEAAAAAQAAQAABHAADAAAAAQABAAABKAADAAAAAQACAAABUgADAAAAAQACAAABUwADAAAABAAAQNaHcwAHAAAMSAAAQN4AAAAAAAgACAAIAAgAAQABAAEAAQAADEhMaW5vAhAAAG1udHJSR0IgWFlaIAfOAAIACQAGADEAAGFjc3BNU0ZUAAAAAElFQyBzUkdCAAAAAAAAAAAAAAAAAAD21gABAAAAANMtSFAgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEWNwcnQAAAFQAAAAM2Rlc2MAAAGEAAAAbHd0cHQAAAHwAAAAFGJrcHQAAAIEAAAAFHJYWVoAAAIYAAAAFGdYWVoAAAIsAAAAFGJYWVoAAAJAAAAAFGRtbmQAAAJUAAAAcGRtZGQAAALEAAAAiHZ1ZWQAAANMAAAAhnZpZXcAAAPUAAAAJGx1bWkAAAP4AAAAFG1lYXMAAAQMAAAAJHRlY2gAAAQwAAAADHJUUkMAAAQ8AAAIDGdUUkMAAAQ8AAAIDGJUUkMAAAQ8AAAIDHRleHQAAAAAQ29weXJpZ2h0IChjKSAxOTk4IEhld2xldHQtUGFja2FyZCBDb21wYW55AABkZXNjAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAEnNSR0IgSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABYWVogAAAAAAAA81EAAQAAAAEWzFhZWiAAAAAAAAAAAAAAAAAAAAAAWFlaIAAAAAAAAG+iAAA49QAAA5BYWVogAAAAAAAAYpkAALeFAAAY2lhZWiAAAAAAAAAkoAAAD4QAALbPZGVzYwAAAAAAAAAWSUVDIGh0dHA6Ly93d3cuaWVjLmNoAAAAAAAAAAAAAAAWSUVDIGh0dHA6Ly93d3cuaWVjLmNoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGRlc2MAAAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAAAAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAAAAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAACxSZWZlcmVuY2UgVmlld2luZyBDb25kaXRpb24gaW4gSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAdmlldwAAAAAAE6T+ABRfLgAQzxQAA+3MAAQTCwADXJ4AAAABWFlaIAAAAAAATAlWAFAAAABXH+dtZWFzAAAAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAACjwAAAAJzaWcgAAAAAENSVCBjdXJ2AAAAAAAABAAAAAAFAAoADwAUABkAHgAjACgALQAyADcAOwBAAEUASgBPAFQAWQBeAGMAaABtAHIAdwB8AIEAhgCLAJAAlQCaAJ8ApACpAK4AsgC3ALwAwQDGAMsA0ADVANsA4ADlAOsA8AD2APsBAQEHAQ0BEwEZAR8BJQErATIBOAE+AUUBTAFSAVkBYAFnAW4BdQF8AYMBiwGSAZoBoQGpAbEBuQHBAckB0QHZAeEB6QHyAfoCAwIMAhQCHQImAi8COAJBAksCVAJdAmcCcQJ6AoQCjgKYAqICrAK2AsECywLVAuAC6wL1AwADCwMWAyEDLQM4A0MDTwNaA2YDcgN+A4oDlgOiA64DugPHA9MD4APsA\/kEBgQTBCAELQQ7BEgEVQRjBHEEfgSMBJoEqAS2BMQE0wThBPAE\/gUNBRwFKwU6BUkFWAVnBXcFhgWWBaYFtQXFBdUF5QX2BgYGFgYnBjcGSAZZBmoGewaMBp0GrwbABtEG4wb1BwcHGQcrBz0HTwdhB3QHhgeZB6wHvwfSB+UH+AgLCB8IMghGCFoIbgiCCJYIqgi+CNII5wj7CRAJJQk6CU8JZAl5CY8JpAm6Cc8J5Qn7ChEKJwo9ClQKagqBCpgKrgrFCtwK8wsLCyILOQtRC2kLgAuYC7ALyAvhC\/kMEgwqDEMMXAx1DI4MpwzADNkM8w0NDSYNQA1aDXQNjg2pDcMN3g34DhMOLg5JDmQOfw6bDrYO0g7uDwkPJQ9BD14Peg+WD7MPzw\/sEAkQJhBDEGEQfhCbELkQ1xD1ERMRMRFPEW0RjBGqEckR6BIHEiYSRRJkEoQSoxLDEuMTAxMjE0MTYxODE6QTxRPlFAYUJxRJFGoUixStFM4U8BUSFTQVVhV4FZsVvRXgFgMWJhZJFmwWjxayFtYW+hcdF0EXZReJF64X0hf3GBsYQBhlGIoYrxjVGPoZIBlFGWsZkRm3Gd0aBBoqGlEadxqeGsUa7BsUGzsbYxuKG7Ib2hwCHCocUhx7HKMczBz1HR4dRx1wHZkdwx3sHhYeQB5qHpQevh7pHxMfPh9pH5Qfvx\/qIBUgQSBsIJggxCDwIRwhSCF1IaEhziH7IiciVSKCIq8i3SMKIzgjZiOUI8Ij8CQfJE0kfCSrJNolCSU4JWgllyXHJfcmJyZXJocmtyboJxgnSSd6J6sn3CgNKD8ocSiiKNQpBik4KWspnSnQKgIqNSpoKpsqzysCKzYraSudK9EsBSw5LG4soizXLQwtQS12Last4S4WLkwugi63Lu4vJC9aL5Evxy\/+MDUwbDCkMNsxEjFKMYIxujHyMioyYzKbMtQzDTNGM38zuDPxNCs0ZTSeNNg1EzVNNYc1wjX9Njc2cjauNuk3JDdgN5w31zgUOFA4jDjIOQU5Qjl\/Obw5+To2OnQ6sjrvOy07azuqO+g8JzxlPKQ84z0iPWE9oT3gPiA+YD6gPuA\/IT9hP6I\/4kAjQGRApkDnQSlBakGsQe5CMEJyQrVC90M6Q31DwEQDREdEikTORRJFVUWaRd5GIkZnRqtG8Ec1R3tHwEgFSEtIkUjXSR1JY0mpSfBKN0p9SsRLDEtTS5pL4kwqTHJMuk0CTUpNk03cTiVObk63TwBPSU+TT91QJ1BxULtRBlFQUZtR5lIxUnxSx1MTU19TqlP2VEJUj1TbVShVdVXCVg9WXFapVvdXRFeSV+BYL1h9WMtZGllpWbhaB1pWWqZa9VtFW5Vb5Vw1XIZc1l0nXXhdyV4aXmxevV8PX2Ffs2AFYFdgqmD8YU9homH1YklinGLwY0Njl2PrZEBklGTpZT1lkmXnZj1mkmboZz1nk2fpaD9olmjsaUNpmmnxakhqn2r3a09rp2v\/bFdsr20IbWBtuW4SbmtuxG8eb3hv0XArcIZw4HE6cZVx8HJLcqZzAXNdc7h0FHRwdMx1KHWFdeF2Pnabdvh3VnezeBF4bnjMeSp5iXnnekZ6pXsEe2N7wnwhfIF84X1BfaF+AX5ifsJ\/I3+Ef+WAR4CogQqBa4HNgjCCkoL0g1eDuoQdhICE44VHhauGDoZyhteHO4efiASIaYjOiTOJmYn+imSKyoswi5aL\/IxjjMqNMY2Yjf+OZo7OjzaPnpAGkG6Q1pE\/kaiSEZJ6kuOTTZO2lCCUipT0lV+VyZY0lp+XCpd1l+CYTJi4mSSZkJn8mmia1ZtCm6+cHJyJnPedZJ3SnkCerp8dn4uf+qBpoNihR6G2oiailqMGo3aj5qRWpMelOKWpphqmi6b9p26n4KhSqMSpN6mpqhyqj6sCq3Wr6axcrNCtRK24ri2uoa8Wr4uwALB1sOqxYLHWskuywrM4s660JbSctRO1irYBtnm28Ldot+C4WbjRuUq5wro7urW7LrunvCG8m70VvY++Cr6Evv+\/er\/1wHDA7MFnwePCX8Lbw1jD1MRRxM7FS8XIxkbGw8dBx7\/IPci8yTrJuco4yrfLNsu2zDXMtc01zbXONs62zzfPuNA50LrRPNG+0j\/SwdNE08bUSdTL1U7V0dZV1tjXXNfg2GTY6Nls2fHadtr724DcBdyK3RDdlt4c3qLfKd+v4DbgveFE4cziU+Lb42Pj6+Rz5PzlhOYN5pbnH+ep6DLovOlG6dDqW+rl63Dr++yG7RHtnO4o7rTvQO\/M8Fjw5fFy8f\/yjPMZ86f0NPTC9VD13vZt9vv3ivgZ+Kj5OPnH+lf65\/t3\/Af8mP0p\/br+S\/7c\/23\/\/w==",
    "BTTAlternateIconData" : "TU0AKgAAQAj\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAYAAAAIAAAADAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAADAAAAAgAAAAGAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADgAAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAOAAAACgAAAAUP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAACAAAAA4AAAAP8AAAD\/AAAA\/wAAAP8AAADAAAAAgAAAAGAAAABAAAAAIP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAQAAAAGAAAACAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAADgAAAAgAAAACD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAKAAAAD\/AAAA\/wAAAP8AAADwAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADwAAAA\/wAAAP8AAAD\/AAAAoAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAPAAAAD\/AAAA\/wAAAMAAAABg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADAAAAA\/wAAAP8AAADwAAAAgP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA0AAAAP8AAAD\/AAAAwAAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAEAAAADAAAAA\/wAAAP8AAADQAAAAMP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADwAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAP8AAACwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAALAAAAD\/AAAA\/wAAAKD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAcAAAAP8AAAD\/AAAA0AAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAPAAAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA8AAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADQAAAA\/wAAAPAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAADAAAADwAAAA\/wAAAND\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAPAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAMAAAAPAAAAD\/AAAAoP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAHAAAAD\/AAAA\/wAAADD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA0AAAAP8AAACw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAsAAAAP8AAADQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAPAAAAD\/AAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAwP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAKD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAAD\/AAAA\/wAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAP8AAAD\/AAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACAAAAA\/wAAAMD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA4AAAAP8AAABg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADg\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADwAAAA\/wAAAFD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAkP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAACg\/\/\/\/AP\/\/\/wAAAADgAAAA\/wAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAFAAAAD\/AAAA4P\/\/\/wAAAAAgAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAAgAAAAYAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAMAAAAD\/AAAAYAAAAIAAAAD\/AAAAgP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACAAAAA\/wAAAIAAAADAAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADAAAAAwAAAAP8AAABA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAEAAAAD\/AAAAwAAAAP8AAAD\/AAAAIP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAA\/wAAAP8AAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/AAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAD\/AAAA\/wAAAP8AAAD\/\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAD\/AAAA\/\/\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAP8AAAD\/AAAA\/wAAAP8AAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAAD\/AAAA\/wAAAMAAAAD\/AAAAQP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABAAAAA\/wAAAMAAAADAAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAYAAAAP8AAADAAAAAgAAAAP8AAACA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAIAAAAD\/AAAAgAAAAGAAAAD\/AAAAwP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADAAAAA\/wAAAGAAAAAgAAAA\/wAAAP\/\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA\/wAAAP8AAAAg\/\/\/\/AAAAAOAAAAD\/AAAAUP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADg\/\/\/\/AP\/\/\/wAAAACgAAAA\/wAAAJD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAAoP\/\/\/wD\/\/\/8AAAAAUAAAAP8AAADw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADwAAAA\/wAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADgAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABgAAAA\/wAAAOD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAwAAAAP8AAACA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAAD\/AAAA\/wAAAED\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAP8AAAD\/AAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAADA\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAMAAAAD\/AAAAoP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAGD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAAD\/AAAA8AAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAgAAAAP8AAADwAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADwAAAA\/wAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAADQAAAA\/wAAALD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAACwAAAA\/wAAAND\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAMAAAAP8AAAD\/AAAAcP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAKAAAAD\/AAAA8AAAADD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA8AAAAP8AAACg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAA0AAAAP8AAADwAAAAMP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAwAAAA8AAAAP8AAADQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAADQAAAA\/wAAAPAAAABQ\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABQAAAA8AAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAANAAAAD\/AAAA\/wAAAHD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADQAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAoAAAAP8AAAD\/AAAAsAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAABAAAACwAAAA\/wAAAP8AAACg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABwAAAA\/wAAAP8AAADwAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAGAAAADwAAAA\/wAAAP8AAABw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAADAAAADQAAAA\/wAAAP8AAADAAAAAQP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAQAAAAMAAAAD\/AAAA\/wAAANAAAAAw\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAIAAAADwAAAA\/wAAAP8AAADAAAAAYP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAABgAAAAwAAAAP8AAAD\/AAAA8AAAAID\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAEAAAAKAAAAD\/AAAA\/wAAAP8AAADwAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAUAAAAKAAAADwAAAA\/wAAAP8AAAD\/AAAAoAAAABD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AAAAAIAAAAIAAAADgAAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAACAAAAAYAAAAEAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAACAAAABAAAAAYAAAAIAAAADAAAAA\/wAAAP8AAAD\/AAAA\/wAAAOAAAACAAAAAEP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AAAAAFAAAACgAAAA4AAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAP8AAADgAAAAoAAAAFD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wAAAAAgAAAAYAAAAIAAAADAAAAAwAAAAP8AAAD\/AAAA\/wAAAP8AAAD\/AAAA\/wAAAMAAAADAAAAAgAAAAGAAAAAg\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8A\/\/\/\/AP\/\/\/wD\/\/\/8AABABAAADAAAAAQBAAAABAQADAAAAAQBAAAABAgADAAAABAAAQM4BAwADAAAAAQABAAABBgADAAAAAQACAAABCgADAAAAAQABAAABEQAEAAAAAQAAAAgBEgADAAAAAQABAAABFQADAAAAAQAEAAABFgADAAAAAQBAAAABFwAEAAAAAQAAQAABHAADAAAAAQABAAABKAADAAAAAQACAAABUgADAAAAAQACAAABUwADAAAABAAAQNaHcwAHAAAMSAAAQN4AAAAAAAgACAAIAAgAAQABAAEAAQAADEhMaW5vAhAAAG1udHJSR0IgWFlaIAfOAAIACQAGADEAAGFjc3BNU0ZUAAAAAElFQyBzUkdCAAAAAAAAAAAAAAAAAAD21gABAAAAANMtSFAgIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAEWNwcnQAAAFQAAAAM2Rlc2MAAAGEAAAAbHd0cHQAAAHwAAAAFGJrcHQAAAIEAAAAFHJYWVoAAAIYAAAAFGdYWVoAAAIsAAAAFGJYWVoAAAJAAAAAFGRtbmQAAAJUAAAAcGRtZGQAAALEAAAAiHZ1ZWQAAANMAAAAhnZpZXcAAAPUAAAAJGx1bWkAAAP4AAAAFG1lYXMAAAQMAAAAJHRlY2gAAAQwAAAADHJUUkMAAAQ8AAAIDGdUUkMAAAQ8AAAIDGJUUkMAAAQ8AAAIDHRleHQAAAAAQ29weXJpZ2h0IChjKSAxOTk4IEhld2xldHQtUGFja2FyZCBDb21wYW55AABkZXNjAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAEnNSR0IgSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABYWVogAAAAAAAA81EAAQAAAAEWzFhZWiAAAAAAAAAAAAAAAAAAAAAAWFlaIAAAAAAAAG+iAAA49QAAA5BYWVogAAAAAAAAYpkAALeFAAAY2lhZWiAAAAAAAAAkoAAAD4QAALbPZGVzYwAAAAAAAAAWSUVDIGh0dHA6Ly93d3cuaWVjLmNoAAAAAAAAAAAAAAAWSUVDIGh0dHA6Ly93d3cuaWVjLmNoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGRlc2MAAAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAAAAAAAAAALklFQyA2MTk2Ni0yLjEgRGVmYXVsdCBSR0IgY29sb3VyIHNwYWNlIC0gc1JHQgAAAAAAAAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAACxSZWZlcmVuY2UgVmlld2luZyBDb25kaXRpb24gaW4gSUVDNjE5NjYtMi4xAAAAAAAAAAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAdmlldwAAAAAAE6T+ABRfLgAQzxQAA+3MAAQTCwADXJ4AAAABWFlaIAAAAAAATAlWAFAAAABXH+dtZWFzAAAAAAAAAAEAAAAAAAAAAAAAAAAAAAAAAAACjwAAAAJzaWcgAAAAAENSVCBjdXJ2AAAAAAAABAAAAAAFAAoADwAUABkAHgAjACgALQAyADcAOwBAAEUASgBPAFQAWQBeAGMAaABtAHIAdwB8AIEAhgCLAJAAlQCaAJ8ApACpAK4AsgC3ALwAwQDGAMsA0ADVANsA4ADlAOsA8AD2APsBAQEHAQ0BEwEZAR8BJQErATIBOAE+AUUBTAFSAVkBYAFnAW4BdQF8AYMBiwGSAZoBoQGpAbEBuQHBAckB0QHZAeEB6QHyAfoCAwIMAhQCHQImAi8COAJBAksCVAJdAmcCcQJ6AoQCjgKYAqICrAK2AsECywLVAuAC6wL1AwADCwMWAyEDLQM4A0MDTwNaA2YDcgN+A4oDlgOiA64DugPHA9MD4APsA\/kEBgQTBCAELQQ7BEgEVQRjBHEEfgSMBJoEqAS2BMQE0wThBPAE\/gUNBRwFKwU6BUkFWAVnBXcFhgWWBaYFtQXFBdUF5QX2BgYGFgYnBjcGSAZZBmoGewaMBp0GrwbABtEG4wb1BwcHGQcrBz0HTwdhB3QHhgeZB6wHvwfSB+UH+AgLCB8IMghGCFoIbgiCCJYIqgi+CNII5wj7CRAJJQk6CU8JZAl5CY8JpAm6Cc8J5Qn7ChEKJwo9ClQKagqBCpgKrgrFCtwK8wsLCyILOQtRC2kLgAuYC7ALyAvhC\/kMEgwqDEMMXAx1DI4MpwzADNkM8w0NDSYNQA1aDXQNjg2pDcMN3g34DhMOLg5JDmQOfw6bDrYO0g7uDwkPJQ9BD14Peg+WD7MPzw\/sEAkQJhBDEGEQfhCbELkQ1xD1ERMRMRFPEW0RjBGqEckR6BIHEiYSRRJkEoQSoxLDEuMTAxMjE0MTYxODE6QTxRPlFAYUJxRJFGoUixStFM4U8BUSFTQVVhV4FZsVvRXgFgMWJhZJFmwWjxayFtYW+hcdF0EXZReJF64X0hf3GBsYQBhlGIoYrxjVGPoZIBlFGWsZkRm3Gd0aBBoqGlEadxqeGsUa7BsUGzsbYxuKG7Ib2hwCHCocUhx7HKMczBz1HR4dRx1wHZkdwx3sHhYeQB5qHpQevh7pHxMfPh9pH5Qfvx\/qIBUgQSBsIJggxCDwIRwhSCF1IaEhziH7IiciVSKCIq8i3SMKIzgjZiOUI8Ij8CQfJE0kfCSrJNolCSU4JWgllyXHJfcmJyZXJocmtyboJxgnSSd6J6sn3CgNKD8ocSiiKNQpBik4KWspnSnQKgIqNSpoKpsqzysCKzYraSudK9EsBSw5LG4soizXLQwtQS12Last4S4WLkwugi63Lu4vJC9aL5Evxy\/+MDUwbDCkMNsxEjFKMYIxujHyMioyYzKbMtQzDTNGM38zuDPxNCs0ZTSeNNg1EzVNNYc1wjX9Njc2cjauNuk3JDdgN5w31zgUOFA4jDjIOQU5Qjl\/Obw5+To2OnQ6sjrvOy07azuqO+g8JzxlPKQ84z0iPWE9oT3gPiA+YD6gPuA\/IT9hP6I\/4kAjQGRApkDnQSlBakGsQe5CMEJyQrVC90M6Q31DwEQDREdEikTORRJFVUWaRd5GIkZnRqtG8Ec1R3tHwEgFSEtIkUjXSR1JY0mpSfBKN0p9SsRLDEtTS5pL4kwqTHJMuk0CTUpNk03cTiVObk63TwBPSU+TT91QJ1BxULtRBlFQUZtR5lIxUnxSx1MTU19TqlP2VEJUj1TbVShVdVXCVg9WXFapVvdXRFeSV+BYL1h9WMtZGllpWbhaB1pWWqZa9VtFW5Vb5Vw1XIZc1l0nXXhdyV4aXmxevV8PX2Ffs2AFYFdgqmD8YU9homH1YklinGLwY0Njl2PrZEBklGTpZT1lkmXnZj1mkmboZz1nk2fpaD9olmjsaUNpmmnxakhqn2r3a09rp2v\/bFdsr20IbWBtuW4SbmtuxG8eb3hv0XArcIZw4HE6cZVx8HJLcqZzAXNdc7h0FHRwdMx1KHWFdeF2Pnabdvh3VnezeBF4bnjMeSp5iXnnekZ6pXsEe2N7wnwhfIF84X1BfaF+AX5ifsJ\/I3+Ef+WAR4CogQqBa4HNgjCCkoL0g1eDuoQdhICE44VHhauGDoZyhteHO4efiASIaYjOiTOJmYn+imSKyoswi5aL\/IxjjMqNMY2Yjf+OZo7OjzaPnpAGkG6Q1pE\/kaiSEZJ6kuOTTZO2lCCUipT0lV+VyZY0lp+XCpd1l+CYTJi4mSSZkJn8mmia1ZtCm6+cHJyJnPedZJ3SnkCerp8dn4uf+qBpoNihR6G2oiailqMGo3aj5qRWpMelOKWpphqmi6b9p26n4KhSqMSpN6mpqhyqj6sCq3Wr6axcrNCtRK24ri2uoa8Wr4uwALB1sOqxYLHWskuywrM4s660JbSctRO1irYBtnm28Ldot+C4WbjRuUq5wro7urW7LrunvCG8m70VvY++Cr6Evv+\/er\/1wHDA7MFnwePCX8Lbw1jD1MRRxM7FS8XIxkbGw8dBx7\/IPci8yTrJuco4yrfLNsu2zDXMtc01zbXONs62zzfPuNA50LrRPNG+0j\/SwdNE08bUSdTL1U7V0dZV1tjXXNfg2GTY6Nls2fHadtr724DcBdyK3RDdlt4c3qLfKd+v4DbgveFE4cziU+Lb42Pj6+Rz5PzlhOYN5pbnH+ep6DLovOlG6dDqW+rl63Dr++yG7RHtnO4o7rTvQO\/M8Fjw5fFy8f\/yjPMZ86f0NPTC9VD13vZt9vv3ivgZ+Kj5OPnH+lf65\/t3\/Af8mP0p\/br+S\/7c\/23\/\/w==",
    "BTTTriggerConfig" : {
      "BTTTouchBarAppleScriptString" : "tell application \"BetterTouchTool\"\r\tset trueToneState to is_true_tone_enabled\r\t\rend tell\r",
      "BTTTouchBarButtonColor" : "110.000001, 193.000004, 56.000000, 255.000000",
      "BTTTouchBarItemPlacement" : 0,
      "BTTTouchBarAppleScriptStringRunOnInit" : false,
      "BTTTouchBarAlwaysShowButton" : false,
      "BTTScriptType" : 0,
      "BTTTouchBarScriptUpdateInterval" : 5,
      "BTTTouchBarButtonWidth" : 100,
      "BTTTouchBarItemIconHeight" : 22,
      "BTTTouchBarAlternateBackgroundColor" : "174.000005, 25.000000, 21.000001, 255.000000",
      "BTTTouchBarAppleScriptUsePath" : 0,
      "BTTTBWidgetWidth" : 400,
      "BTTTouchBarColorRegex" : "true",
      "BTTTouchBarItemIconWidth" : 22,
      "BTTTouchBarButtonName" : "toggle true tone",
      "BTTTouchBarButtonFontSize" : 15,
      "BTTTouchBarIconTextOffset" : 5,
      "BTTTouchBarOnlyShowIcon" : false,
      "BTTTouchBarFreeSpaceAfterButton" : 5,
      "BTTTouchBarItemPadding" : 0
it doesnt turn off after 5 seconds. i chnaged the time and tried again. it doesnt have any effect.
and the script i use worked great until the last btt upgrade.
Weird, it seems to work fine here. Which version are you on currently?
BetterTouchTool 3.335 and Mac OS 10.15.3 on a 16" MacBook Pro
Same as mine. Could you copy & paste the full configuration for that trigger here? (select the widget in BTT cmd+c & cmd+v here)
"BTTWidgetName" : "TrueTone Warning",
"BTTTriggerType" : 639,
"BTTTriggerTypeDescription" : "Apple Script / JavaScript Widget",
"BTTTriggerClass" : "BTTTriggerTypeTouchBar",
"BTTPredefinedActionType" : 205,
"BTTPredefinedActionName" : "Open Touch Bar Group With Name",
"BTTOpenGroupWithName" : "More Settings",
"BTTEnabled2" : 1,
"BTTRepeatDelay" : 0,
"BTTUUID" : "133DA276-457D-4196-84AC-8173933C7F6F",
"BTTEnabled" : 1,
"BTTModifierMode" : 0,
"BTTOrder" : 16,
"BTTDisplayOrder" : 0,
"BTTMergeIntoTouchBarGroups" : 0,
"BTTAlternateIconData" : "TU0AKgAAQAgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIgAAAKwAAADxAAAA8AAAAKwAAAAhAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGwAAAOoAAAD_AAAA_wAAAP8AAAD_AAAA6QAAABsAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKsAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAACqAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADYAAAD+AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAADoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADDAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADGAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABQAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAFAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAAAA1QAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADYAAAABQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAaQAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAGkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADAAAAOcAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADpAAAADgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAIEAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAIEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABYAAADyAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD2AAAAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACZAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAJkAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAoAAAA+wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD8AAAAKwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAsgAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAALIAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAPgAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAQwAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAMYAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAMoAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFgAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAWAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAYAAADbAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAN4AAAAHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABvAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA8gAAALsAAAC7AAAAuwAAALsAAADyAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAQAAAA6wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAANEAAAAAAAAAAAAAAAAAAAAAAAAA0gAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAO4AAAASAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAiAAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADZAAAAAAAAAAAAAAAAAAAAAAAAANoAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAiQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAGwAAAPUAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA4AAAAAAAAAAAAAAAAAAAAAAAAADhAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAPcAAAAfAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAKAAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAOgAAAAAAAAAAAAAAAAAAAAAAAAA6QAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAogAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC4AAAD9AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADwAAAAAAAAAAAAAAAAAAAAAAAAAPEAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP0AAAAzAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAC5AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA9wAAAAAAAAAAAAAAAAAAAAAAAAD4AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAvgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABBAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP4AAAABAAAAAAAAAAAAAAABAAAA_gAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAABHAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAzQAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAABwAAAAAAAAAAAAAACAAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA0gAAAAMAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAXwAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAA4AAAAAAAAAAAAAAA8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAABgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACAAAAOEAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAAWAAAAAAAAAAAAAAAXAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA5AAAAAoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHcAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAHQAAAAAAAAAAAAAAHgAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAB5AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABEAAADtAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAACUAAAAAAAAAAAAAACYAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA8gAAABcAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAACPAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAAsAAAAAAAAAAAAAAAtAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAACRAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAhAAAA+AAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAANAAAAAAAAAAAAAAANQAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA+gAAACUAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAqAAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAADwAAAAAAAAAAAAAADwAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAACqAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAANQAAAP4AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAADoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAL0AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADGAAAAAQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAE0AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAE8AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAMAAADUAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD+AAAAywAAAMsAAAD+AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADXAAAABAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABkAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD7AAAARwAAAAAAAAAAAAAASAAAAPwAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAGgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALAAAA5QAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAAtgAAAAAAAAAAAAAAAAAAAAAAAAC3AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADnAAAADAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAfQAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAALYAAAAAAAAAAAAAAAAAAAAAAAAAuAAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAIEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAFwAAAPIAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD8AAAASAAAAAAAAAAAAAAASQAAAPwAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD0AAAAGQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAI4AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP4AAADMAAAAzAAAAP4AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAJEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADmAAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAADmAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA9QAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA8wAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAALsAAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAALgAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAzAAAA9gAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAPUAAAAyAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAADIAAAC4AAAA8wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA_wAAAP8AAAD_AAAA8wAAALcAAAAxAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABIBAAADAAAAAQBAAAABAQADAAAAAQBAAAABAgADAAAABAAAQPYBAwADAAAAAQABAAABBgADAAAAAQACAAABCgADAAAAAQABAAABEQAEAAAAAQAAAAgBEgADAAAAAQABAAABFQADAAAAAQAEAAABFgADAAAAAQBAAAABFwAEAAAAAQAAQAABGgAFAAAAAQAAQOYBGwAFAAAAAQAAQO4BHAADAAAAAQABAAABKAADAAAAAQACAAABUgADAAAAAQACAAABUwADAAAABAAAQP6HcwAHAAAMSAAAQQYAAAAAAAAADAAAAAEAAAAMAAAAAQAIAAgACAAIAAEAAQABAAEAAAxITGlubwIQAABtbnRyUkdCIFhZWiAHzgACAAkABgAxAABhY3NwTVNGVAAAAABJRUMgc1JHQgAAAAAAAAAAAAAAAAAA9tYAAQAAAADTLUhQICAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABFjcHJ0AAABUAAAADNkZXNjAAABhAAAAGx3dHB0AAAB8AAAABRia3B0AAACBAAAABRyWFlaAAACGAAAABRnWFlaAAACLAAAABRiWFlaAAACQAAAABRkbW5kAAACVAAAAHBkbWRkAAACxAAAAIh2dWVkAAADTAAAAIZ2aWV3AAAD1AAAACRsdW1pAAAD+AAAABRtZWFzAAAEDAAAACR0ZWNoAAAEMAAAAAxyVFJDAAAEPAAACAxnVFJDAAAEPAAACAxiVFJDAAAEPAAACAx0ZXh0AAAAAENvcHlyaWdodCAoYykgMTk5OCBIZXdsZXR0LVBhY2thcmQgQ29tcGFueQAAZGVzYwAAAAAAAAASc1JHQiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAABJzUkdCIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAWFlaIAAAAAAAAPNRAAEAAAABFsxYWVogAAAAAAAAAAAAAAAAAAAAAFhZWiAAAAAAAABvogAAOPUAAAOQWFlaIAAAAAAAAGKZAAC3hQAAGNpYWVogAAAAAAAAJKAAAA+EAAC2z2Rlc2MAAAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAFklFQyBodHRwOi8vd3d3LmllYy5jaAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABkZXNjAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAC5JRUMgNjE5NjYtMi4xIERlZmF1bHQgUkdCIGNvbG91ciBzcGFjZSAtIHNSR0IAAAAAAAAAAAAAAAAAAAAAAAAAAAAAZGVzYwAAAAAAAAAsUmVmZXJlbmNlIFZpZXdpbmcgQ29uZGl0aW9uIGluIElFQzYxOTY2LTIuMQAAAAAAAAAAAAAALFJlZmVyZW5jZSBWaWV3aW5nIENvbmRpdGlvbiBpbiBJRUM2MTk2Ni0yLjEAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAHZpZXcAAAAAABOk_gAUXy4AEM8UAAPtzAAEEwsAA1yeAAAAAVhZWiAAAAAAAEwJVgBQAAAAVx_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_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_AkHyRNJHwkqyTaJQklOCVoJZclxyX3JicmVyaHJrcm6CcYJ0kneierJ9woDSg_KHEooijUKQYpOClrKZ0p0CoCKjUqaCqbKs8rAis2K2krnSvRLAUsOSxuLKIs1y0MLUEtdi2rLeEuFi5MLoIuty7uLyQvWi+RL8cv_jA1MGwwpDDbMRIxSjGCMbox8jIqMmMymzLUMw0zRjN_M7gz8TQrNGU0njTYNRM1TTWHNcI1_TY3NnI2rjbpNyQ3YDecN9c4FDhQOIw4yDkFOUI5fzm8Ofk6Njp0OrI67zstO2s7qjvoPCc8ZTykPOM9Ij1hPaE94D4gPmA+oD7gPyE_YT+iP+JAI0BkQKZA50EpQWpBrEHuQjBCckK1QvdDOkN9Q8BEA0RHRIpEzkUSRVVFmkXeRiJGZ0arRvBHNUd7R8BIBUhLSJFI10kdSWNJqUnwSjdKfUrESwxLU0uaS+JMKkxyTLpNAk1KTZNN3E4lTm5Ot08AT0lPk0_dUCdQcVC7UQZRUFGbUeZSMVJ8UsdTE1NfU6pT9lRCVI9U21UoVXVVwlYPVlxWqVb3V0RXklfgWC9YfVjLWRpZaVm4WgdaVlqmWvVbRVuVW+VcNVyGXNZdJ114XcleGl5sXr1fD19hX7NgBWBXYKpg_GFPYaJh9WJJYpxi8GNDY5dj62RAZJRk6WU9ZZJl52Y9ZpJm6Gc9Z5Nn6Wg_aJZo7GlDaZpp8WpIap9q92tPa6dr_2xXbK9tCG1gbbluEm5rbsRvHm94b9FwK3CGcOBxOnGVcfByS3KmcwFzXXO4dBR0cHTMdSh1hXXhdj52m3b4d1Z3s3gReG54zHkqeYl553pGeqV7BHtje8J8IXyBfOF9QX2hfgF+Yn7CfyN_hH_lgEeAqIEKgWuBzYIwgpKC9INXg7qEHYSAhOOFR4Wrhg6GcobXhzuHn4gEiGmIzokziZmJ_opkisqLMIuWi_yMY4zKjTGNmI3_jmaOzo82j56QBpBukNaRP5GokhGSepLjk02TtpQglIqU9JVflcmWNJaflwqXdZfgmEyYuJkkmZCZ_JpomtWbQpuvnByciZz3nWSd0p5Anq6fHZ+Ln_qgaaDYoUehtqImopajBqN2o+akVqTHpTilqaYapoum_adup+CoUqjEqTepqaocqo+rAqt1q+msXKzQrUStuK4trqGvFq+LsACwdbDqsWCx1rJLssKzOLOutCW0nLUTtYq2AbZ5tvC3aLfguFm40blKucK6O7q1uy67p7whvJu9Fb2Pvgq+hL7_v3q_9cBwwOzBZ8Hjwl_C28NYw9TEUcTOxUvFyMZGxsPHQce_yD3IvMk6ybnKOMq3yzbLtsw1zLXNNc21zjbOts83z7jQOdC60TzRvtI_0sHTRNPG1EnUy9VO1dHWVdbY11zX4Nhk2OjZbNnx2nba+9uA3AXcit0Q3ZbeHN6i3ynfr+A24L3hROHM4lPi2+Nj4+vkc+T85YTmDeaW5x_nqegy6LzpRunQ6lvq5etw6_vshu0R7ZzuKO6070DvzPBY8OXxcvH_8ozzGfOn9DT0wvVQ9d72bfb794r4Gfio+Tj5x_pX+uf7d_wH_Jj9Kf26_kv+3P9t__8=",
"BTTTouchBarFreeSpaceAfterButton" : 2,
"BTTTouchBarOnlyShowIcon" : true,
"BTTTouchBarButtonColor" : "0.000000, 0.000000, 0.000000, 255.000000",
"BTTTouchBarItemPlacement" : 2,
"BTTTouchBarAppleScriptStringRunOnInit" : true,
"BTTTouchBarFontColorAlternate" : "255.000000, 255.000000, 255.000000, 255.000000",
"BTTTouchBarButtonWidth" : 20,
"BTTTouchBarItemIconHeight" : 20,
"BTTTouchBarButtonUseFixedWidth" : 1,
"BTTTouchBarAlternateBackgroundColor" : "0.000000, 0.000000, 0.000000, 216.000000",
"BTTTouchBarItemIconWidth" : 20,
"BTTTouchBarButtonName" : "TrueTone Warning",
"BTTTouchBarAppleScriptString" : "tell application "BetterTouchTool"\n\t\tset trueToneState to is_true_tone_enabled\nend tell",
"BTTTouchBarButtonCornerRadius" : 0,
Ah now I understand. You only have an alternate icon but no standard icon for that button. I think that's causing the issue. I'll have a look!
would it be fixed if i add a transaprent png as an icon?
and do you have a theory why my actual true tone button doesnt show the standart icon until is press it? (like in the video i posted)
For now you can fix it by changing the script to
		if trueToneState is true then
			return "true"
		 else
		 	return ""
		 end if
end tell
(returning empty strings will hide any widget)
I will add a fix to the next BTT update.
thanks, i will try that. but why did it work for like two months now but suddenly not anymore and is there a better way to show the true tone warming besides making an invisible button like it did?
The touch bar logic has been rewritten completely to provide better performance. I forgot about the possibility to have a alternate icon set but no standard icon. That's why it broke :wink: I'm uploading a alpha that should fix it in 5 minutes.
The best way to hide widgets is to return an empty string in case you want to hide it.
ah ok, i understand! nice.
ok, i have no idea but i will try to find out how to achieve this :smiley:
quick sidequestion. i want to make a warning similar to my truetone warning, when i activate amphetamine but i dont know how. any tips?
i tried it with "app did lauch" in the "other" tab but i dont want a group to open, only a warning icon (button) to show.
works perfect! <3
is amphetamine an app?
If you are running the alpha that will upload in 5 minutes, you can use an apple script like this:
		set appRunning to is_app_running "Amphetamine"
		if appRunning is true then
			return "true"
		 else
		 	return ""
		 end if
end tell
It will only work with the alpha (v3.337) though and you need to make sure to write the app name correctly.
yes, its an app that prevents my mac from going to sleep.
thanks. first class support here. :slight_smile:
unfortunately the script doesnt return "true" when amphetamine is running. could it be, because its a menu bar app?
