Hey there! I work as a Support person and love the macro ability of BTT, but was wondering if there was any way to be able to get an HTML element from a webpage and insert that into my macro?
For example, if I'm sending a standard greeting to a customer we have a name field on the form I use that I could parse out a first name for using standard Javascript, but I'd then like to then be able to pipe that into my BTT macro. Is there a way to do this?
The example code writes the text of the reply preview from this page into a BTT variable ("myBTTVariable"):
set myJavascriptCode to "(function(){return document.getElementsByClassName('d-editor-preview')[0].innerText})()"
tell application "Safari"
tell first window
tell current tab
set theResult to do JavaScript myJavascriptCode
end tell
end tell
end tell
set_string_variable "myBTTVariable" to theResult
end tell
To run the example:
Choose Preferences from the Safari menu, changing to the Advanced panel, and enabling “Show Develop menu in menu bar”, and then choosing Allow JavaScript from Apple Events from the Develop . You can then turn off the Develop menu if desired.
Click Reply on this page and write any text
Run the Code in Script-Editor or with the BTT "Run Apple Script" action.
Apologies for the super late reply on this, just getting around to it now.
Trying to get this to work in Chrome, but when I try I'm getting console errors. This is what I have:
set myJavascriptCode to "(function(){return document.getElementById('connectFollowWidgetAction').innerText})()"
tell application "Google Chrome"
tell active tab of front window
set theResult to execute javascript myJavascriptCode
end tell
end tell
end tell
Even though the document.getElementById('connectFollowWidgetAction').innerText works in the console manually, when I try to execute the script it says that innerText is null
If I use your document.getElementsByClassName here it works fine.
Edit: Yeah, if I do something like getElementsByClassName on my page in the console it returns over a couple dozen objects, but when running through the script it returns nothing. Studff like console logging/alerts work fine when running from the script, so I don't know what's going on.
Edit2: Realized it was because I was inside of a frame. Used window.frames to break out and it's working as expected now. Thanks!
