Hi all,
Is there a way to trigger an automation that is based on a date/time condition trigger AND an additional condition such as "When macOS awakes sleeps OR starts"?
The use case that I'm trying to implement is:
- Every Friday at 8am, run the following AppleScript
- However, if the laptop is off, then run the AppleScript when the laptop wakes or starts but only if it's on a Friday
I know I could configure the second case with a custom AppleScript that runs each time I start the machine and then checks the time/date. However, was curious if there's a BTT native way to support this?
Thanks
