An issue with an icon in the floating menu
I don't know why, but recently, I noticed an issue with an icon in my floating menu.
The icon in purple changed to the Finder icon for some reason, and I had to disable and enable the menu to look normal again.
The icon should look like this:
But it looks like this:
Can I do something about it, or should I just wait for a fix update?
Thanks
Could you copy & paste that item json here? I think there was a recent fix for when you had specifically set dark-mode icons. They haven't been used/shown before in some configurations but might now show up.
How do I do that?
I thought it is a menu item to choose from. But it wasn't.
ah you need to copy it (cmd+c), then paste it here (cmd+v)
oh ok. But as I tried to paste it in here, this popped up.
So I created a file from the code.
BTT - Icon.txt (158.7 KB)
Ah interesting issue - for some reason it is using a previously defined image based icon even though you have selected sfsymbol by now. I'll fix that.
For now you can fix it yourself by clicking this button to reset the icon:
Ah ok. Yeah, that's weird.
I reset the icon, so hopefully it's fixed now.
Thanks
