"Als Hyper-Key fungieren" popup – how to disable
Whenever I press CapsLock, which is configured as Hyperkey here, I get a popup:
and in the recently used section I see this:
The "Firefox trigger" is not run. My settings for CapsLock are these:
I'd like to prevent the popup from appearing – anything I can do?
Thanks in advance
You have configured it twice, delete one of them then it won't show the conflict menu
Indeed – thanks a bunch. No idea why/how that happened
