Alpha 4.250 'crash/restart loop'
after updating to Alpha 4.250 BTT is crashing and restarting relaunching itself (looping), after 5-10 times (sometimes) the crash/restart stops... It might be related to sleep/wakeup somehow as it happens then.
Any idea how it can be fixed....
Edit: I found that the loop stops when I close the Stream Deck app....
Thx
Christian
  • Type of Mac:
  • macOS version: MacBookPro M1 Max
  • BetterTouchTool version: 4.250
can you check whether you can find a crashlog in the macOS console app (in the crash reports section on the left)?
There are loads of BTT crashlogs today, I send one to your mail...
Thx a lot.
Christian
can you try v 4.252? (https://folivora.ai/releases/btt4.252-42520.zip)
Great! It looks like 4.252 fixed it....
Thx a lot.
Christian
