Allow the ability to use BTT when external keyboards. I have a handwriting keyboard installed on the iPad that works tremendously well and I use it all the time. It would be great if you allow that to be used would BTT remote so that I can handwrite input.
unfortunately sending key events etc. only works reliably with the built in keyboard, especially on systems which are not english.
However you can enable the "Allow third party keyboards" option in the BTT Remote settings (in the "General" section). It may not work well though.
I have tested this and it works very well. Thank you for your fast response!
