I started with GoldenChaos preset, and modded from there, then exported it, and imported into another machine. The import works without error, but what results appears to be the stock GoldenChaos, without any of my mods.
Is this intended? Is there somewhere I can sync over the modifications I made? As far as I can tell this shouldn't be intended behaviour.
