It's currently possible to remove the first line in the "Advanced Conditions" window for triggers (excepting CAGs) via its "–" button. (I.e. the "All/Any/None" selection.) Doing so causes an exception (see below) and an empty list with no immediate way to re-add a condition. (Though you can do so by closing the windows and re-opening it – it will revert to the default.)
I guess the first "–" button should simply be removed. No point in having no conditions at all. Or if so, there should be a button to re-add one.
- Type of Mac: 2017 MBP
- macOS version: 12.6.3
- BetterTouchTool version: 4.069
Exception Name: NSInvalidArgumentException
Description: *** -[NSTextView replaceCharactersInRange:withString:]: nil NSString given.
User Info: (null)
0 CoreFoundation 0x00007ff819e67773 __exceptionPreprocess + 242
1 libobjc.A.dylib 0x00007ff819bc7bc3 objc_exception_throw + 48
2 CoreFoundation 0x00007ff819e675da +[NSException exceptionWithName:reason:userInfo:] + 0
3 AppKit 0x00007ff81ca54699 -[NSTextView replaceCharactersInRange:withString:] + 256
4 BetterTouchTool 0x00000001097bdb90 -[BTTTriggerConditionsVC ruleEditorRowsDidChange:] + 297
5 AppKit 0x00007ff81cbc4df4 -[NSRuleEditor _postRuleOptionChangedNotification] + 109
6 AppKit 0x00007ff81d12c486 -[NSRuleEditor _deleteSlice:] + 598
7 AppKit 0x00007ff81ca280ce -[NSApplication(NSResponder) sendAction:to:from:] + 288
8 AppKit 0x00007ff81ca27f74 -[NSControl sendAction:to:] + 86
9 AppKit 0x00007ff81ca27ea6 __26-[NSCell _sendActionFrom:]_block_invoke + 131
10 AppKit 0x00007ff81ca27daf -[NSCell _sendActionFrom:] + 171
11 AppKit 0x00007ff81ca27cf7 -[NSButtonCell _sendActionFrom:] + 96
12 AppKit 0x00007ff81ca24b6f NSControlTrackMouse + 1813
13 AppKit 0x00007ff81ca24436 -[NSCell trackMouse:inRect:ofView:untilMouseUp:] + 121
14 AppKit 0x00007ff81ca24306 -[NSButtonCell trackMouse:inRect:ofView:untilMouseUp:] + 679
15 AppKit 0x00007ff81ca236d6 -[NSControl mouseDown:] + 678
16 AppKit 0x00007ff81ca21bc1 -[NSWindow(NSEventRouting) _handleMouseDownEvent:isDelayedEvent:] + 4859
17 AppKit 0x00007ff81c995d7e -[NSWindow(NSEventRouting) _reallySendEvent:isDelayedEvent:] + 2582
18 AppKit 0x00007ff81c99514e -[NSWindow(NSEventRouting) sendEvent:] + 352
19 AppKit 0x00007ff81c993524 -[NSApplication(NSEvent) sendEvent:] + 352
20 BetterTouchTool 0x0000000109823d1e -[BTTApplication sendEvent:] + 1373
21 AppKit 0x00007ff81cc4c18b -[NSApplication _handleEvent:] + 65
22 AppKit 0x00007ff81c814d3e -[NSApplication run] + 623
23 AppKit 0x00007ff81c7e8c97 NSApplicationMain + 817
24 dyld 0x0000000115c2252e start + 462
