Advanced Settings>Three finger drag optimization
Today I have found in "Settings>Advanced Settings>Trackpad>General" that there is a drop-down menu for "Three finger drag optimizations". It says "set to default if you are not using the system three finger drag":
I am using three fingers on trackpad for moving windows using the native macos settings since paleolithic (running Sequoia 15.8.1 now) and everything has always worked well.
But I have seen these posts saying that there are problems in Golden Gate:
My questions:
  1. Do I keep the selection of "Default (recommended but three finger drag may not work well)" or do I change to "Optimize for three finger drag (has negative effects on window snapping and snap area performance)" in BTT settings?
  2. Will I loose this feature If I update to macos Golden Gate?
I have added various optimizations that should mostly mitigate the Golden Gate changes by now.
You can leave it at default if all your BTT gestures work as expected
