Additional Outline List View UI >> Custom column width does not persist
I'm using BTT 6.510 under macOS 26.5 Tahoe.
It's been many weeks I've been experiencing an issue with the "Additional Outline List View UI", hoping somebody sees the bug and reports it, but apparently no one has, so there it is.
I'm a heavy user of the "Additional Outline List View UI" preferences option, as I prefer this UI view miles ahead of the default one. However, when I custom resize the columns width in this view (namely "Config", "Trigger Name" and "Actions Executed On Trigger"), the custom width does not persist after closing BTT's window. It always reverts to the default width.
Here's what I'm talking about (1st pic is custom width columns, 2nd pic is how it appears when reopening BTT after closing):
After diving into the app's preferences, I came across these options:
While those options work for the sidebar and the config sidebar, they do not work with the "Additional Outline List View UI" (Trigger and Action namely).
Would it be possible to add a default width for the columns of the Outline List View that can be customized by the user? Maybe it already exists, maybe it's an hidden preference; if it's the case, it would be great for this to be visible and customizable.
Many thanks in advance,
Robert
I forgot to tell: I've been using this view for a long time, way before the new UI came along. I've started experiencing this issue starting with the first BTT version featuring the new UI, and it's been like this since then.
unfortunately that view mode is being phased out. It has been disabled for new users for quite a while and it does not receive updates anymore. I know some users prefer it, but it is too complex for me to maintain two such different view modes - especially because the native macOS backing view used for the outline list view is itself pretty outdated.
