Battery Widget forces you to have a battery icon next to percentage. Would be great if users could optionally remove the icon and only see the percentage (ie 97%
Hopefully this is easy to implement as it would be useful!
As a current workaround, you can set "Corner Radius" to about 70 and apply only to the left edge. This will 'hide' that icon but will also result in the icon "twitching" every time it updates (every minute or so).
Mine currently reads only % and hours left.
@Andreas_Hegenberg Would it be possible to officially add a setting to hide the battery icon.
And also another setting to hide the widget all together when on 100% battery.
Basically allow this third party solution work officially:
