Frank1
April 29, 2023, 1:09pm
1
I would like to use this action.
The problem is that the names of the window (at the end) changes.
It always starts with "Scrivener DB NOTES" and ends with something.
I was hoping a "*" would help, but unfortunately not.
How does BTT find this window? Thanks.
Dirk
April 30, 2023, 9:52am
2
Try using .* as a placeholder (RegEx):
Scrivener DB NOTES.*
RegEx (Google)
Frank1
April 30, 2023, 11:23am
3
Thank you, Dirk! As I was just able to find out, everything is actually working now. No idea why it didn't work before.
With or without ".", "*". It doesn't need any more characters if the beginning of the name is correct.
Strange thing is, "." stands for any character, but only one . Right?
So this: "Scrivener DB NOT. "
should not find this Window.
"Scrivener DB NOTES "
But it does. With or without ".", which is ok for me.
Dirk
April 30, 2023, 11:37am
4
See the Docu RegEx
The dot stands only for one character and the asterisk for any number of the previous selection. So .* means any number of any characters.
Frank1
April 30, 2023, 11:42am
5
" . Der Punkt steht für ein beliebiges Zeichen und kann somit jedes Zeichen finden."
... ein ... Zeichen.
should not find this.
Alles gut. Es zeigt wahrscheinlich nur, dass RegEx hier nicht zur Anwendung kommt
Dirk
April 30, 2023, 12:04pm
6
Doch. RegEx wird verwendet. Es kann sein, die Funktion standardmäßig „StartWith“ verwendet.
