I have a handful of Keyboard Shortcuts and Named Triggers that have multiple actions associated to them. Often times the actions are executed out of order. I've resorted to putting half second or 1 second delays between all actions and while that helps, I still run into some out of order execution. I haven't kept track of how often this happens but I would get 10-20% of the time (when using delays between all actions).
***Update: After testing this a bunch of times over the past week, I believe it only happens the first time after the MBP wakes up from sleep.
N/A
- Type of Mac: MacBook Pro (13-inch, 2020)
- macOS version: Big Sur 11.2.3
- BetterTouchTool version: 3.561 (1701)
