I have a lot of triggers (especially for the Touch Bar) but I am only using a few currently. It would be great if I could hide all disabled triggers. This makes editing and finding the active ones much simpler
good idea.
For now you could create a separate preset "disabled" which you disable and move your disabled triggers there (select all of them, then click in the main menubar, Presets => Move Selected Triggers to Preset
Yeah, I basically did that for now. Hope it gets implemented at some point.
