A system setting for Stage Manager is ignored
When you have:
  • Stage Manager ON
  • the following system setting OFF: "When switching to an application, switch to a Space with open windows for the application"
Then do:
  • On desktop/space X, trigger "Save currently active window"
  • Go to space Y
  • trigger "Go back to saved active window" (which moves back to space X)
If both spaces have a window of the same application (eg. a browser), which is active in space X but not in space Y, triggering "Go back to saved active window" switches the windows in space Y so both spaces end up with a window of the same app active.
This is an error because the system setting mentioned earlier is OFF (otherwise it would be correct).
Mac actions, such as switching spaces, don't cause this error, and BTT actions to switch spaces don't either.
keyboard
  • Type of Mac:
    mini m2 pro
  • macOS version:
    14.6.1
  • BetterTouchTool version: (please post the exact version - not just "the latest one")
    4.680
