Ah YES! That did it. I can't believe I made such a little (and stupid) mistake. Thank you for having the patience to help me. I will put some time into studying the code and maybe learning a bit and helping you in return.
Got any last tips on were to begin with objective-c on MacOS?
Most of my Obj-C experience comes from iOS actually, but if youāre new to the language or frameworks Stanfordās course(s) is always a good place to start.
Didnāt realize that GitUp wasnāt being maintained. Fork looks promising, thanks for the tip.
What in particular are you looking for in VPN support? Itās not something I use multiple times during my workflow (Iām usually on some intranet already), but perhaps @GoldenChaos could create a compatible widget.
Is it just be, the Calendar widget is not working properly these days? It seems the eventkit-service is running but it always says that I have "No upcoming meetings" and Im not sure why this is happening.
Thank you for your reply. I have already tried the latest commit, but still it didn't work. I have tried re-setting up the preset but it didn't work so maybe i have to reinstall BTT, or something is wrong with the BTT Webserver or my Calendar.
I was somehow able to solve that issue...! Caused by my stupid mistakes, 1, the service-runner.sh script wasn't executed because the action was not visible for some reason. 2nd, I had to change the BTT Webserver address, http to https. Sorry I messed up the thread, and thank you sooo much!
@andrewchidden - can you expand on what may or may not work for your presets in BTT v2.6xx? I understand it may not be so simple to say preset X or Y won't work, but perhaps it is. I'd also understand if it's just better to downgrade to ensure full compatibility.
I'm curious before diving in. I would like to use (many of) your presets, though there are a couple features introduced since 2.6xx that I really like too.
I believe itās mostly appearance things that will break, per another personās comment above. Iām planning on upgrading later this week if BTT seems stable enough (I canāt help but feel the last few releases have been a bit flaky) and export then.
If youād like to start using the preset with v2.6xx right away, Iād recommend trying to either:
Directly import into v2.6xx. If you see weird backwards compatibility issues w.r.t. visual glitches, then remove the preset.
Import into v2.536, quit, then open v2.6xx. The preset should show up correctly in v2.6xx.
Hey, sorry for the lack of updates. Iāve actually been fixing some bugs and improving performance in control strip services, but havenāt had enough time to finish updating the tests. Hoping to push something this week.
I certainly appreciate the update, but please don't apologize! I am just grateful you're willing and able to share your skills in developing these presets (and I'm sure everyone else here agrees). Plus, it sounds like you're working away on them, and doing a properly thorough job of it.
I will say I am kind of excited and looking forward to your update. Despite my other thread about wanting a simpler version, the more I've used and tinkered with BTT, the more I really like your complete workup.
I haven't had much time myself to try your suggestions above, so I'm just continuing to live with my cobbled-together touch bar.
