3 finger double tap not working properly
I have a 3-finger tap to open a new tab in my browser and 3-finger double tap to close the current tab. When I attempt a 3-finger double tap, it closes the current tab but then opens a new tab. How do I fix this to separate the two operations?
I think I found a weird threading issue, would be great if you could check whether it works for you with v5.103
The latest version of BTT fixed this issue.
