For some reason, 3 and 4 finger taps aren't working in 9 cases out of 10.
do you have three finger dragging enabled on your system? (that breaks things in BTT, but you can enable a compatibility mode in the BTT trackpad preferences)
Could you send me an export of your preset? (or alternatively got to help => export diagnostic debug information and send the result to andreas@folivora.ai )
I can't reproduce it here, but I assume it may happen with a specific combination of gestures active)
Same issue, three finger tip taps not working in application. Three finger dragging enabled as well as BTT trackpad preferences compatibility with no help. Tip taps wont register in app. test.bttpreset (171.7 KB)
Did you recently change the values in this screen? It seems like BTT was using the value for 4 finger taps also for the three finger tap and in your case that value was set to a very small value.
