OS 12.3.1 BTT 3.996
After long sleep/wake I get the permissions dialog and have to restart BTT. Supremely bothersome.
OS 12.3.1 BTT 3.996
There were quite some bugs in 12.3.1 related to permissions. Is there a reason you are on this macOS version? (it also contains many security issues that have been fixed by Apple since)
Avoiding Ventura more than anything. Not worried about security context of this machine as much as app stability.
Upgrading to 12.6.2 in hopes of resolving this issue.
Thanks.
In case it does not help, I'd try to delete this file (maybe make a copy first):
~/Library/Preferences/com.hegenberg.BetterTouchTool.plist (go there via Finder => Go => Go To Folder, make sure to include the ~). Could also be a weird file permission problem.
Will do - the oddity is that it goes away after restart BTT and does not feel like it appears until next wake. Will get OS updated (and del file if needed) and report back of there are still issues.
Thanks
