2 Finger Touchbar Swipe for volume stopped working.
Two finger swipe shows proper on touchbar, but does not activate the volume controls like it has previously.
touchbar
  • Type of Mac: 2017 touchbar
  • macOS version: 10.14.4
  • BetterTouchTool version: 2.813
It works with 3 fingers or 4 finger swipe just not 2
since one of the recent versions it respects the "enabled / visible" checkbox (it didn't do that due to a bug before). Maybe the gesture you are using for volume control is disabled?
Well im the asshole. Thanks! not sure how i missed this.
the 3 and 4 didnt seem to respect it so i just totally overlooked it,
Thanks for your continued work app is better than ever.
