2 finger swipe from the left edge works for me. However, the gesture stops work when I enable the option that forces 2 finger swipes to have to reach the edge. I don't know if this should be a bug report or a feature request, but as it stands, swiping from the outer edge is just not working when this option is enabled. There are also no way to have custom swipe out to the edge do a different thing than just 2 finger swiping.
Affected input device (e.g. MacBook Trackpad, Magic Mouse/Trackpad, Touch Bar, etc.): Macbook Trackpad and Magic Trackpad 2
- Type of Mac: MacBook Pro 2015 15"
- macOS version: macOS Monterey 12.4
- BetterTouchTool version: 3.816
